I found my subroutines are not overwriting the xml file when I run simulations on HPC. I have initialised the case and there is no error in compile.log. But I found the properties I defined by subroutines, such as thermophysical properties were not overwriting those default values set by GUI. That probably means the subroutines were not executed though they have been compiled.
I suspect it may be related to the installation of code_saturne on HPC, but have no idea which part was wrong.
Thanks in advance,
Xiaoxue
user subroutines not executed
Re: user subroutines not executed
Could you provide at least the relevant info as recommended on the forum usage guidelines (xml and user sources, system, version and install info, ...) ?
I'm attaching the files in the zip folder. It includes the xml file (cylinder.xml), compile.log, performance.log, setup.log, listing file and the user subroutines. The version I've installed is code_saturne 5.2.1.
Could you have a look to see if anything is wrong?
Xiaoxue
Xiaoxue
- files.zip
- (33.36 KiB) Downloaded 170 times
I do not see any "obvious" issue, but there might subtle errors such as indexing issues.
To check for this:
To check for this:
- did you try running on a debug build ? some errors may be caught earlier
- did you try using a "minimal" user subroutine, such as simply setting the max number of time steps in cs_user_parameters.f90, or calling a simple "print" statement in usphyv to check if you go through the routine or not (if the print has an effect, it means the issue is due to something else, if not, we may have the same issue as that observed on Ubuntu packages
- which type of architecture are you running on and how was the code installed ? (I see in your config.log you seem to be using spack ?)
I've managed to solve it. The mistake I made was that when I submit the job, I didn't specify that simulation should run from the cs_solver generated after compilation of the subroutines. Instead, simulation was run using the cs_solver in the folder where code_saturne was installed.
Xiaoxue
Xiaoxue
OK good. For your info, if you setup the post-install correctly (see install documentation, but basically amounts to setting a few values in the <install_prefix>/etc/code_saturne.cfg), you can use a batch system directly with the regular Code_Saturne scripts, and use the "code_saturne submit" command, which can be handy.
