Anisotropic thermal conductivity
Luciano Garelli
Post by Luciano Garelli »
I'm solving a Conjugated Heat Transfer (CHT) problem using the internal coupling capability of CS modelling several solid parts. Some of this parts has anisotropic thermal conductivity. Is it possible to set this property?
The only way that I found is through the idften tensor, but I'm no sure because this tensor is associated with the turbulence viscosity.
Re: Anisotropic thermal conductivity
Hello Luciano,
As some colleagues reminded me this is tested in the FVCA7 verification cases, here is the setup from a few months ago for anisotropic (CASE2) and orthotropic (case3) pure diffusion cases.
I am not too familiar with this test case, but I hope you find an appropriate example in it.
I did not add the meshes, as this is jus to see how the settings are done.
fvca_anisotropic.tar.gz
(38.01 KiB) Downloaded 179 times
Luciano Garelli
Thanks for the example. The files inside the tar.gz seems to be symbolic links.
Could you check it.
Thank you very much.
Sorry for the incorrect archive.
This one should be ok.
(52.86 KiB) Downloaded 174 times
Luciano Garelli
Thank you for the example. I have being running few very simple example and I have a pair of questions.
For the case of the temperature field the "anisotropic_turbulent_viscosity" tensor "visten" should be filled with the thermal conductivity or the thermal conductivity/(rho*cp). I'm using the last option.
If a reference thermal conductivity is defined, the resulting anisotropic thermal conductivity is the addition of this reference thermal conductivity plus the "visten" tensor.
Finally, checking the temperature value at the boundary faces looks like it is not taken into account the anisotropic field, is just computed with the reference thermal conductivity.
Thanks in advance.
