Boundary condition definition error
roberto.bernetti
Post by roberto.bernetti »
Hi
I'm running a steady analysis on a box of water simulating the diffusivity of temperature and salinity.
At the inlet I imposed velocity of water and imposed values of temperature and salinity.
During the run I got the following error:
  (out of 1300)
  has boundary condition type 0, center (7.98961, 50.0653, 4.75973)
../../../../src/code_saturne-5.0.9/src/base/cs_boundary_conditions.c:363: Fatal error.
  For details, read the end of the calculation log,
  or visualize the error postprocessing output.
The center face coordinates seem to be on the inlet boundary, but I cant guess which type of condition is the "type 0"
In the preprocessor log appear a :
        Default family
         (no group)
  Number of internal faces :  1823196
  Number of boundary faces :     1300
and 1300 is the difference between the surface elements of the boundary and the preprocessor stated bundary faces
Main mesh properties
  Number of cells:                                934222
  Number of internal faces:                      1823196
  Number of boundary faces:                        90496
  Number of vertices:                             179897
Is there any relations?
Saluti
Roberto
Luciano Garelli
Re: Boundary condition definition error
Post by Luciano Garelli »
Hello Roberto,
This error appears when some boundary face doesn't have a boundary condition imposed. You can try to select all the boundary faces that weren't selected. To do this, add a new boundary condition in the "definition of boundary region" and in the selection criteria will be appear a selection not including the previous groups ( for example not(inlet or wall or outlet) )
roberto.bernetti
you was right I forgot to name a physical gruop in Gmsh and some bounding element faces has group
Saluti
Roberto
