Best practice restarting case
AHIC
Post by AHIC »
I'm not able to launch my simulation with the previous data study. What is it the best practice for the restarting case please ?
Antech
Re: Best practice restarting case
Post by Antech »
Hello. When you choose to restart the calculation, Saturne immediately asks you for the results directory. In the window appeared choose the checkpoint directory of the previous run. Then it should restart normally.
Please note that Saturne 5.x only supports simple restarts with the same mesh (without interpolation). In some cases calculation will not run properly even on the same mesh. For example, if you changed the turbulence model from SST to RSM in high-velocity aerodynamic case, the solution may diverge or it will take enormous time per timestep so it's more practical to just start the new calculation with RSM and first-order approximation, switching to the second order then.
If you choose the checkpoint directory right but the calculation doesn't restart, please, provide the listing file for developers to be able to check what's wrong with the restart algo or with the case itself.
tpa
Post by tpa »
Have you increased the number of iterations for the restart?
