Comparing smooth and rough walls
asda9786
Post by asda9786 » Mon Apr 01, 2019 12:05 pm
Hello fellow Code_Saturne users.
I am running a steady state simulation with rough walls and would like to compare it to smooth walls. For my rough walls, I believe i Have met convergence despite what seems to look like a noisy signal. Is there any way to alleviate the noise, maybe by constructing some sort of mean field. Or would maybe running a unsteady simulation be better?
I have attached the velocity field below.
Luciano Garelli
Re: Comparing smooth and rough walls
Post by Luciano Garelli » Mon Apr 01, 2019 3:30 pm
I think that you can use an octave or python script to calculate an average value after convergence is reached.
Best Regards,
asda9786
Post by asda9786 » Mon Apr 01, 2019 5:28 pm
Thank you for the reply Luciano. I am currently trying to see if I can get an average value through the software 'paraview'.
If this isn't possible I will try another method. :D
Post by Yvan Fournier » Mon Apr 01, 2019 7:32 pm
You can also construct a mean field using time averages in Code_Saturne.
You can activate those directly from the GUI.
Luciano Garelli
Post by Luciano Garelli » Mon Apr 01, 2019 8:51 pm
In paraview you can apply the "Temporal Statistics" filter. it will compute the average, the max and min values or use the time averages in Code_Saturne as Yvan mention.
Best Regards,
asda9786
Post by asda9786 » Thu Apr 04, 2019 10:17 am
Thank you for the response I will try these techniques out in Code_Saturne and Paraview respectively.
