access velocity x,y,z
Ionut G
Post by Ionut G »
I need to access the velocity, on x, y and z direction, from inside the cs_wall_functions_2scales_log, "cs_wall_functions.h" file.
I assume the variable "vel" is the velocity in the x direction, it is correct?
From doxygen documentation, I understood that I should use this "cs_real_3_t *cvar_vel = (cs_real_3_t *)CS_F_(u)->val" but after when I try to access "uy = cvar_vel[cell_id][1]" I don't know "[cell_id]".
Can anyone help me solve this problem?
Thank you very much,
Ionut
Re: access velocity x,y,z
When accessing the general velocity field, the access to cvar_vel described in the Doxygen documentation allows acessing components x, y, z for a given cell (cell_id).
But in the wall functions, the "vel" velocity passed to the cs_wall_functions_2scales_log is the relative tangential velocity (see clptur.f90, starting line 595 on master branch to see how it is computed).
So the velocity accessible inside the wall functions is in a local reference frame, not in the "absolute" reference frame.
Ionut G
Post by Ionut G »
Thank you very much, Yvan
