MEDCoupling support
Posted: Sun Oct 16, 2016 1:27 am
I hope to build Code_Saturne 4.0.6 with SALOME-MECA-2016-LGPL-1. However, it did not successfully complete the build.
The install_saturne.log file says:
configure: WARNING: no MEDCoupling support
configure: error: in `/home/fafan/packages/Code_saturne-4.0.6_openmpi/code_saturne-4.0.6_openmpi.build':
configure: error: MEDCoupling support is requested, but test for MEDCoupling failed!
And, the config.log file says:
| #include <MEDCouplingUMesh.hxx>
| int
| main ()
| using namespace ParaMEDMEM;
| MEDCouplingUMesh *m = MEDCouplingUMesh::New();
| return 0;
configure:26113: WARNING: no MEDCoupling support
configure:26178: error: in `/home/fafan/packages/Code_saturne-4.0.6_openmpi/code_saturne-4.0.6_openmpi.build':
configure:26180: error: MEDCoupling support is requested, but test for MEDCoupling failed!
If Salome is not requested in the build, then it can finish building successfully. (Looks like it does not require MEDCoupling in this case.)
My complete install_saturne.log and config.log file are attached here. Please help how this problem can be resolved. Thank you.
- ffan
| int
| main ()
| return 0;
- ffan
