input parameters depending results
jgd23
Post by jgd23 »
hello,
Is it possible to give some input parameters (for example an input temperature imposed on an inlet) which are depending of measurements (for example the temperature average of a domain). In Comsol, it's a really helpfull feature which permits to gain lot of time. Adding an equation to adjust an input variable to have the desired flux or temp on a spcecific boundary or domain.
Julien
Re: input parameters depending results
Yes, it is possible, but for advanced settings, you will need to edit user subroutines, such as cs_user_boundary_conditions.f90. You can check the Doxygen documentation for examples.
jgd23
Post by jgd23 »
That's a good news but it seems to be quite difficult to do for me. I have to use results from other parts on the geometry. Maybe someone can help me to start... or with a more explicit example.
Julien
Spatially averaged, or sampled ? The best examples to point to depend on this.
jgd23
Post by jgd23 »
Yes, spatially average. But the better case for my study should be the average temperature on a solid domain where the temperature is computed with syrthes.
Julien
I believe you can use Syrthes user subroutines to compute the average temperature, but there is no simple way to exchange that info with Code_Saturne (this would be much easier with Code_Saturne/Code_Saturne coupling, which should be available for thermal cases in version 5.0.
What you want to do would be relatively easy to add by modifying non-user subroutines, but for now, I don't see a simple way to do it only with user subroutines (an modifying the code itself depends on how comfortable with programming).
I'll update this if I have a better idea.
jgd23
Post by jgd23 »
hello,
I have not really a large experience as programmer.
I think that it's possible for my problem to adjust the inlet temperature with "only" the heat flux measured on a desired surface (surface of the solid in contact with the fluid domain).
So maybe, it's possible to make a CS/CS coupling in this way with user subroutine?
Julien
You can obtain the flux for the previous time step quite easily, but the one for the current time step is computed after the user boundary condition definitions, so that would be more difficult to use.
For the previous time step, when defining your inlet conditions (in cs_user_boundary_conditions.f90), you can first do a selection of the faces used for Syrthes coupling (using the matching criteria), then call post_boundary_thermal_flux. Do not forget to add "use post_util" near the other "use" statements at near the beginning of the file.
So basically, if you have:
integer          ilelt, nlelt
double precision tflux
double precision, allocatable, dimension(:) :: bflux
allocate(lstelt(nfabor))
allocate(bflux(nfabor))
call getfbr("selection_criteria", nlelt, lstelt)
call post_util(nlelt, lstelt, bflux)
tflux = 0
do ilelt = 1, nlelet
  tflux = tflux + bflux(ilelt)
if (irangp.ge.0) then
  call parsom(tflux)
endif
Replacing with your own selection criteria, you will have the total flux from the previous time step in tflux. Using that, you can adapt the rest of the examples fond for boundary conditions in the Doxygen documentation.
