Hi everyone,
I have a file with all the velocity components for the y-coordinate, is there a way to read this file in code saturne?
Thanks for your help
andrea
Velocity profile from file
Re: Velocity profile from file
Do you want to use this velocity field to initialize the simulation?. If so, please check the cs_user_initialization-base.f90 and cs_user_initialization-compressible.f90 files at /SRC/EXAMPLES
Thanks for the reply, no is a boundary condition.
Ok,
Did you check cs_user_boundary_conditions-base.f90, cs_user_boundary_conditions-advanced.f90, cs_user_boundary_conditions-mapped_inlet.f90 ?
The file with the velocity comes from another simulation with a different mesh or same mesh? If the profile comes from a different mesh you will have to map or interpolate the values.
Also check this post http://code-saturne.org/forum/viewtopic.php?f=2&t=1872
Hi,Luciano Garelli wrote:Ok,
Yes the mesh is the same. I checked the files, but what for me is not clear is how to loop over the y-coordinate.
Thanks for your time.
Inside of the boundary faces loop, you can access to the coordinates of the centers of the boundary faces thought the pointer cdgfbo
! Boundary faces of group '3'
call getfbr('3', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
! y-coordinate Face center
ycoord = cdgfbo(2, ifac)
enddo
