uselen subroutine change from CS 2.0 to CS 3.0
Posted: Fri Mar 27, 2015 7:12 am
by husanhao
Dear all,
Can anyone please tell me what is the change for the subroutine "uselen.f90" from CS 2.0 to CS 3.0?
Thanks for your answer.
Best Regards
Eric
Re: uselen subroutine change from CS 2.0 to CS 3.0
Posted: Fri Mar 27, 2015 10:23 am
by Brian Angel
I've been looking through the source and user files for uselen.f90 in CS v2.0 and v3.0 but cannot fond this routine. Can you pls confirm that this is indeed the routine that you are wanting to know more about?
Brian Angel.
Posted: Sat Mar 28, 2015 10:09 pm
by husanhao
Actually, I am curious about what are the change for "elec" subroutines from CS2.0 to CS3.0
Recently, I try to simulate the DC electrical arc between two electrodes, and I found some references about that, however, that simulation is based on CS2.0, so I try to figure what is the different setting between CS2.0 to CS3.0
Below link shows all the "elec" subroutines in CS2.0
http://code-saturne.org/viewvc/saturne/ ... athrev=722
And for the uselen.f90, I can only found that routine in CS2.0 but not in CS3.0
So, I just want to know can I ignore that subroutine if I want to use CS3.0 for the electrical arc simulation.
Best Regards
Eric
Posted: Mon Mar 30, 2015 1:32 pm
by Brian Angel
I have been looking through the src/elec source code directory for CS v3.0.1. In v2.0, the routine uselen.f90 has various "if" conditions related to "ippmod(ieljou)". If I do a grep -R of "ieljou" in the v3.0 src/elec directory, I can see the same "if" conditions in the routines elini1, elflux, elveri, ellecd, elreca, eliniv, elvarp and elprop.
None of these routines are in the v2.0 src/elec directory hence it would appear that uselen has been replaced by a certain number or all of these new routines. Hence, it would appear that you can ignore the uselen.f90 routine from CS v2.0.
I suggest that you try it and see what happens.
Brian Angel.
Posted: Mon Mar 30, 2015 5:44 pm
by husanhao
Dear Brian Angel,
Thanks for your reply!!!
Best Regards
Eric
Posted: Sat Apr 18, 2015 7:29 pm
by Jacques Fontaine
uselen was a dedicated function for fields postprocessing for electric arcs module in v2.0. In v3.0, you can make postprocessing on the unified and general prostpro function (cs_user_postprocess_var).
