Partition problems
MartianDuan
Partition problems
Post by MartianDuan »
Dear developers and user,
I am using code_saturne 3.0.1 and code_saturne 3.0.3 on the Clusters like ARCHER or ICEBER in University of Sheffield.
I just found code_saturne won't generate the partition file like 'partition_domain_***' on these two clusters. I did some test with the previous case, which sucessfully generated the parition file with subroutines. However it failed as well.
I had tried the different method, like 'scotch' and 'helbert cuve'.
Can you please give me some suggestions? Two subroutines are attached
Thanks in advance,
Kindest regards,
Yu.
cs_user_performance_tuning.c
(8.51 KiB) Downloaded 168 times
cs_user_scripts.py
(12.81 KiB) Downloaded 173 times
Re: Partition problems
What do the listing/log files say ?
MartianDuan
I did find any listing.log, Since what I did is just to initialize the domain. I remember the it does give me the partition file, even if I just initialize the case.
Am I wrong?
Kindest regards,
Yu.
Yvan Fournier wrote:Hello,
MartianDuan
Sorry for bothering you. I found the problem. I forget the set '-preprocess' in the 'cs_user_script.py'.
This is the reason that the code_saturne did not give me the partition file.
Thanks for your time.
Kindest regards,
Yu.
