gamma, Cv, and Cp
stefann
gamma, Cv, and Cp
Post by stefann »
Hello:
With other CFD solvers, we are normally able to input two of the three: gamma (Cp/Cv), isobaric specific heat Cp, and/or isochoric specific heat Cv.
In the GUI I only see the ability to input Cp.
1) Feature request: Can the GUI be updated to allow gamma and/or Cv?
2) Can someone provide an example how to use the user functions to be able to modify these variables?
3) What is the default value assumed for the compressible model perfect gas with constant gamma?
Stefan
Brian Angel
Re: gamma, Cv, and Cp
Post by Brian Angel »
Concerning point 2), you can use cs_user_physical_properties to set the value of Cp. For point 3), §8.7 of the V3.0 user guide details of what physical properties can be modified using the routines uscfx1 and uscfx2.
More information on points 3) and 1) may also be provided by others on this forum.
Brian Angel.
Erwan Le Coupanec
Post by Erwan Le Coupanec »
When using the compressible module,
is computed as follows:
where is the universal gas constant,
is the gas molar mass (you can set it through the GUI or in a user subroutine),
is the reference specific heat at constant pressure (that you can also set).
is as follows:
For now, the compressible module is only available for perfect gas law with constant , hence implementing an other state law is not straightforward (can not be done through user subroutines) and requires to modify the file src/cfbl/cfther.f90.
Erwan.
stefann
Post by stefann »
This is a really great explaination. Thank you!
Stefan
