Calculation Restart Problems
attene
Re: Calculation Restart Problems
Post by attene »
I tried a restart and It may worked but one thing it is not clear: my residual.csv shows the same number of iteration as the first calculation; although the file was written at the end of the restart calcultion.
I did two steady simulation:
1) 10 iteration
2-restart) 15 iterations
FA
Luciano Garelli
Post by Luciano Garelli »
It's strange... you should have the number of iterations of each run, like in the following example.
You can force the flush of the listing, residuals ant time_stat using the control_file, check the user guide there is info about the use of the control_file.
attene
Post by attene »
Hi Luciano,
thanks you for your answer!
I was thinking I might have made a mistake launching the restart: maybe I should have launched it from the checkpoint directory!? I will try doing that and looking at the use of the control file.
FA
attene
Post by attene »
Hi Luciano,
I read about the use of the control file in the user guide. All the main options are listed but I do not have a clear idea of what suits my issue. What does the flush option do?
FA
attene
Post by attene »
Hi everybody,
problem solved! I was launching the job from the wrong directory.
The restart was not pointing at the checkpoint directory of the previous calculation.
FA
attene
Post by attene »
Hi everybody,
still a question regarding a restart from a job (RESU/YYYYMMdd-hhmm) which was restarted; please forgive the play of words: in practical terms in the folder I am considering (YYYYMMdd-hhmm) there are both a checkpoint and a restart directories.
If I want to do a new restart from this job; do I have to point the new job to the restart directory or the checkpoint directory?
Both checkpoint and restart directories contain the files for a restart (main and auxiliary).
Hope I have been clear enough...
FA
attene
Post by attene »
attene wrote: Thu Sep 20, 2018 9:43 am Hi everybody,
FA
Regarding my post I think the answer is the checkpoint directory because the restart is created in YYYYMMdd-hhmm when a job "is called" from the checkpoint directory.
Best
FA
A computation reads a restart (if present) and generates a checkpoint.
The restart in an execution directory is usually a symbolic link to a checkpoint from a previous run (except maybe on Windows where it might be a copy).
So you probably want the checkpoint.
