Error on CS 5.1.3 usage
jcastas
Post by jcastas »
I have installed successfully the CS 5.1.3. with Salome_Meca 2017.( I think... )
After the reading the tutorial (https://www.code-saturne.org/cms/sites/ ... _Study.pdf).
I have error when i follow the "Mesh quality criteria" section steps. ( see my print screens).
Error message:
File "/home/joaoc/Code_Saturne/5.1.3/code_saturne-5.1.3/arch/Linux_x86_64/bin/code_saturne", line 76, in
retcode = cs.execute()
File "/home/joaoc/Code_Saturne/5.1.3/code_saturne-5.1.3/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 93, in execute
File "/home/joaoc/Code_Saturne/5.1.3/code_saturne-5.1.3/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 168, in run
File "/home/joaoc/Code_Saturne/5.1.3/code_saturne-5.1.3/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_run.py", line 387, in main
return run(argv, pkg)[0]
File "/home/joaoc/Code_Saturne/5.1.3/code_saturne-5.1.3/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_run.py", line 375, in run
stages=stages)
File "/home/joaoc/Code_Saturne/5.1.3/code_saturne-5.1.3/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 1907, in run
self.set_result_dir(force_id)
File "/home/joaoc/Code_Saturne/5.1.3/code_saturne-5.1.3/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 527, in set_result_dir
raise RunCaseError(err_str)
cs_case_domain.RunCaseError:
Results directory: /home/joaoc/Desktop/salome_test/cfd_test/test_1/1/RESU/1 already exists.
Calculation will not be run.
It there any idea how i can solve this error?
Than you and nice regards,
João
Re: Error on CS 5.1.3 usage
Yes, if you force the "run_id", you need to delete the subdirectory in RESU first. Otherwise, just leave the "run_id" section empty.
jcastas
Post by jcastas »
Thanks for the reply Ivan.
I have removed the Run id and it seems to start something. However it gives an error:
  Preparing calculation data
  Preprocessing calculation
  Starting calculation
/home/joaoc/Code_Saturne/5.1.3/code_saturne-5.1.3/arch/Linux_x86_64/libexec/code_saturne/cs_solver was built without XML support,
so parameter file "setup.xml" may not be loaded.
  Saving calculation results
Error in calculation stage.
This means there is a XML problem? how can i fix it?
cheers!
jcastas
Post by jcastas »
i have already solved the previous error. I have instaled the correct xml lib.
#  Name    Use   Install  Path
hdf5       yes   no       /home/joaoc/salome_meca/V2017.0.2/prerequisites/Hdf5-1814
cgns       no    no       None
med        yes   no       /home/joaoc/salome_meca/V2017.0.2/tools/Medfichier-321
scotch     no    no       None
parmetis   no    no       None
libxml2    auto  no       None
I am ending the pipe tutorial https://www.code-saturne.org/cms/sites/ ... _Study.pdf, but it gives me an error at the end the calculation phase.
see also the figure attached
                      Code_Saturne
 Version:   5.1
 Path:      /home/joaoc/Code_Saturne/5.1.3/code_saturne-5.1.3/arch/Linux_x86_64
 Result directory:
   /home/joaoc/Desktop/salome_test/cfd_test/PIPESTUDY/CASE1/RESU/20180228-0859
can i fix it?
thanks again!
João
Could you check or post the files recommended in the error message and in the forum usage recommendations ?
jcastas
Post by jcastas »
Good morning Ivan,
do you mean this "listing" file?
cheers,
listing.txt
(20.83 KiB) Downloaded 518 times
Yes; did you read the end of the file ?
jcastas
Post by jcastas »
Yes.
The file said something about the boundary conditions. i have configures them again and no error occurred, but now i have new error... this seems to be different from the previous one.
/home/joaoc/Desktop/code_install/code_saturne-5.1.3/src/base/cs_log_iteration.c:839: Fatal error.
Invalid (not-a-number) values detected for a field.
   1: 0x7fd1e48b5a17 <+0x12ba17>                      (libsaturne.so.5)
   2: 0x7fd1e48b77a8 <cs_log_iteration+0x18>          (libsaturne.so.5)
   3: 0x7fd1e482c0ea <caltri_+0x2387>                 (libsaturne.so.5)
   4: 0x7fd1e48032db <cs_run+0x52b>                   (libsaturne.so.5)
   5: 0x7fd1e4802c65 <main+0x125>                     (libsaturne.so.5)
   6: 0x7fd1e43e0830 <__libc_start_main+0xf0>         (libc.so.6)
   7: 0x4007d9     <_start+0x29>                    (cs_solver)
am i misshing something?
cheers
listing.txt
(330.53 KiB) Downloaded 515 times
It seems the case is progressively diverging. The CFL number increases pretty fast, so you probably have either a bad quality mesh or a too large time step.
In any case, the time step you used is not the value from the tutorial, so you need to better check your setup.
