code_aster coupling example
Post by Yvan Fournier » Sun Dec 15, 2019 3:38 am
The code_aster coupling will be rewritten so as not to require YACS and be adaptable to newer code_aster versions in the future. Preliminary work has been done n v6.1 for this.
For version 6.0, the coupling has been simplified so as to remove the "milieu" module beween versions 6.0.0 and 6.0.1, so the previous case setups require minor adaptations.
The attached file contains an updated case, tested on master (before preparation of switch to MPI, so between commits c025afd0 and d8dc66ef) and v6.0 (commit 3c652a49 and later), tested with Salome_Meca 2017.
externecylindresconcentriques.tar.gz
(103.1 KiB) Downloaded 94 times
