Flow around a cylinder: Fluid-structure interaction
Post by Yvan Fournier » Sat Apr 21, 2018 11:01 pm
This is a demo case in order to illustrate the mobile mesh (ALE) capability of Code_Saturne in the frame of Fluid-structure interaction. This occurs when fluid flow causes displacement or deformation of the structure. This deformation, in turn, changes the boundary conditions for the fluid flow.
The setup is provided as an example for Code_Saturne 5.0 (adapted from an older setup).
cylinder.med
(660.69 KiB) Downloaded 199 times
(96.51 KiB) Not downloaded yet
cylinder.xml
(8.45 KiB) Downloaded 213 times
jcharris
Re: Flow around a cylinder: Fluid-structure interaction
Post by jcharris » Mon Jun 24, 2019 4:16 pm
Just as a suggestion, perhaps this could be used to update the tutorial page (which still has documentation for running the test with version 2.0) ?
