orthotropic and temperature-dependent heat conduction in Syrthes possible?
kathi
Post by kathi » Mon Mar 25, 2019 5:58 pm
hello,
is it possible with Syrthes to model an orthotropic AND temperature-dependent heat conduction?
In the user guide (syrthes4_user_guide.pdf) I find in chap 3.1.3
"Materials handled" :
Cp = Cp (x, y, z, t, T, . . . )
which means that the heat conduc coef may depend on Temperature.
Is this valid also for orthotropic heat conduction? And which user subroutine must I use for this?
Many thanks in advance for you help,
kathi
kathi
Re: orthotropic and temperature-dependent heat conduction in Syrthes possible?
Post by kathi » Thu Apr 04, 2019 3:00 pm
can someone who knows, please help me answering my question?
thank you kathi
best regards
kathi
Post by Yvan Fournier » Sat Apr 06, 2019 1:07 pm
I see no reason why it should not be possible. I guess you need to check in user_cond.c, but I am not a regular Syrthes user, so never tried it.
If your case includes fluid flow and no transparent radiation coupling or contact thermal resistances, you could also try it using Code_Saturne's internal thermal coupling, which will allow such heat conduction. It would probably be a bit slower than Syrthes, but have the more complete Code_Saturne toolchain.
