Field names
char * algo
char * est_error_pre_2
char * est_error_der_2
char * est_error_cor_2
char * est_error_tot_2
◆ algo
char* algo
Fields used to check algorithm behavior.
Fields of the form "algo:<type>_<variable_name>" are reserved by the code to allow visualization of some intermediate computational field values.
If the user creates such a field, and the code calls the matching operator, this field will be updated automatically.
Current reserved fields are:
  • algo:predicted_velocity Velocity field after the prediction step, cell-based field of dimension 3.
  • algo:predicted_velocity_divergence Divergence of the velocity field after the prediction step, cell-based field of dimension 1.
  • algo:velocity_divergence Divergence of the velocity for the VOF module, cell-based field of dimension 1.
  • algo:pressure_gradient Pressure gradient, cell-based field of dimension 3.
  • algo:gradient_ supplemented with a transported field name Field gradient, cell-based field of dimension 3x the dimension of the corresponding field.
  • algo:turbulent_flux_production_ supplemented with a transported field name Field corresponding to the production of u'T' if scalar taken is temperature, cell-based field of dimension 3.
  • algo:velocity_gradient Velocity gradient, cell-based field of dimension 3x3.
  • algo:pressure_gradient_increment Gradient of the pressure increment solved in the correction step, cell-based field of dimension 3.
  • algo:rij_divergence Divergence of the Reynolds stress in the momentum equation for Reynolds stress RANS models, cell-based field of dimension 3.
  • algo:rij_production So called production term in Reynolds stress RANS models, cell-based field of dimension 6.
  • algo:rij_pressure_strain_correlation So called pressure strain correlation term in Reynolds stress RANS models, cell-based field of dimension 6.
  • algo:rij_buoyancy So called buoyancy term in Reynolds stress RANS models, cell-based field of dimension 6.
  • algo:k_production So called production term in k-epsilon RANS models, cell-based field of dimension 1.
  • algo:k_buoyancy So called buoyancy term in k-epsilon RANS models, cell-based field of dimension 1.
  • algo:turbulent_flux_divergence Divergence of the turbulent flux in the energy equation, cell-based field of dimension 1.
  • algo:grad_clip_factor_<variable_name> Least-squares gradient clip factor if gradient clipping is activated (scalar field on cells).
  • algo:grad_b_iter_<variable_name> Number of iterations for convergence of fixed-point algorithm for least-squares boundary gradient of vector and tensor fields. (scalar field on boundary faces).
  • algo:b_velocity_inout Boundary field to visualize entering velocity at outlets.
◆ est_error_cor_2
char* est_error_cor_2
Error estimator for Navier-Stokes: correction.
The estimator $ \eta^{\,corr}_{\,i,k}(\vect{u}^{\,n+1})$ comes directly from the mass flow calculated with the updated velocity field:
\begin{eqnarray*}\eta^{\,corr}_{\,i,k}(\vect{u}^{\,n+1})=
|\Omega_i|^{\,\delta_{\,2,k}}\ |div (\rho^n \vect{u}^{n+1}) - \Gamma|
\end{eqnarray*}
  • The velocities $\vect{u}^{n+1}$ are taken at the cell centers, the divergence is calculated after projection on the faces. $ \,\delta_{\,2,k}$ represents the Kronecker symbol.
  • The first family, k=1, is the absolute raw value of the divergence of the mass flow minus the mass source term. The second family, $k=2$, represents a physical property and allows to evaluate the difference in $kg.s^{\,-1}$.
  • Ideally, it is equal to zero when the Poisson equation is solved exactly and the projection from the mass flux at the faces to the velocity at the cell centers is made in a set of functions with null divergence.
◆ est_error_der_2
char* est_error_der_2
Error estimator for Navier-Stokes: drift.
The estimator $\eta^{\,der}_{\,i,k}(\vect{u}^{\,n+1})$ is based on the following quantity (intrinsic to the code):
\begin{eqnarray*}\eta^{\,der}_{\,i,k}(\vect{u}^{\,n+1})
   &=& {|\Omega_i|}^{(k-2)/2}
      || \divs (\text{corrected mass flow after the pressure step})
      - \Gamma||_{{L}^{2}(\Omega_i)}
\\ &=& {|\Omega_i|}^{(1-k)/2}
     | \divs (\text{corrected mass flow after the pressure step})- \Gamma|
\end{eqnarray*}
  • Ideally, it is equal to zero when the Poisson equation related to the pressure is solved exactly.
◆ est_error_pre_2
char* est_error_pre_2
Error estimator for Navier-Stokes: prediction.
After the velocity prediction step (yielding $\vect{u}^*$), the estimator $\eta^{\,pred}_{\,i,k}(\vect{u}^*)$, local variable calculated at every cell $ \Omega_i $, is created from $\vect{\mathcal R}^{\,pred}(\vect{u}^*)$, which represents the residual of the equation solved during this step: $\vect{u}$ and $ P $:
\begin{eqnarray*}  \vect{\mathcal R}^{\,pred}(\vect{u}^*)
      & = & \rho^n \dfrac{\vect{u}^*-\vect{u}^n}{\Delta t}
          + \rho^n \vect{u}^n \cdot \gradt (\vect{u}^*)
          - \divv \left((\mu+\mu_t)^n \gradt (\vect{u}^*) \right)
          + \grad(P^n)
  \\  & - & \text{rest of the right-hand member }
           (\vect{u}^n, P^n, \text{other variables}^n)
\end{eqnarray*}
  • By definition: $ \eta^{\,pred}_{\,i,k}(\vect{u}^*)= {|\Omega_i|}^{\,(k-2)/2}\ ||\vect{\mathcal R}^{\,pred}(\vect{u}^*)|| _{{IL}^{2}(\Omega_i)} $
  • The first family, k=1, suppresses the volume $ |\Omega_i| $ which intrinsicly appears with the norm $ {IL}^{2}(\Omega_i) $.
  • The second family, k=2, exactly represents the norm $ {IL}^{2}(\Omega_i) $. The size of the cell therefore appears in its calculation and induces a weighting effect.
  • $ \eta^{\,pred}_{\,i,k}(\vect{u}^*)$ is ideally equal to zero when the reconstruction methods are perfect and the associated system is solved exactly.
◆ est_error_tot_2
char* est_error_tot_2
Error estimator for Navier-Stokes: total.
The estimator $ \eta^{\,tot}_{\,i,k}(\vect{u}^{\,n+1})$, local variable calculated at every cell $\Omega_i$, is based on the quantity $\vect{\mathcal R}^{\,tot}(\vect{u}^{\,n+1})$, which represents the residual of the equation using the updated values of $\vect{u}$ and $P$:
          + \grad(P^n)
\end{eqnarray*}
  • By definition: $ \eta^{\,tot}_{\,i,k}(\vect{u}^{\,n+1})= {|\Omega_i|}^{\,(k-2)/2}\ ||\vect{\mathcal R}^{\,tot}(\vect{u}^{\,n+1})||
  _{{I\hspace{-.25em}L}^{2}(\Omega_i)} $
  • The mass flux in the convective term is recalculated from $\vect{u}^{n+1}$ expressed at the cell centers (and not taken from the updated mass flow at the faces).
  • As for the prediction estimator:
