fvm_nodal_append.h
1#ifndef __FVM_NODAL_APPEND_H__
2#define __FVM_NODAL_APPEND_H__
5 * Append sections to a nodal representation associated with a mesh
30#include "base/cs_defs.h"
33 * Local headers
36#include "fvm/fvm_defs.h"
37#include "fvm/fvm_nodal.h"
38
43/*=============================================================================
44 * Macro definitions
46
48 * Type definitions
50
51/*=============================================================================
52 * Static global variables
53 *============================================================================*/
54
55/*=============================================================================
56 * Public function prototypes
58
59/*----------------------------------------------------------------------------
60 * Append a new section to an existing fvm_nodal mesh, and transfer
61 * ownership of the given connectivity and optional parent number arrays to
62 * that section.
63 *
64 * parameters:
65 * this_nodal <-> nodal mesh structure
66 * n_elements <-- number of elements to add
67 * type <-- type of elements to add
68 * face_index <-- polyhedron -> faces index (O to n-1)
69 * size: n_elements + 1
70 * face_num <-- polyhedron -> face numbers (1 to n, signed,
71 * > 0 for outwards pointing face normal
72 * < 0 for inwards pointing face normal);
73 * size: face_index[n_elements]
74 * vertex_index <-- polygon face -> vertices index (O to n-1)
75 * size: face_index[n_elements]
76 * vertex_num <-- element -> vertex connectivity
77 * parent_element_id <-- element -> parent element id (0 to n-1) if non
78 * trivial (i.e. if element definitions correspond
79 * to a subset of the parent mesh), NULL otherwise
80 *----------------------------------------------------------------------------*/
81
82void
83fvm_nodal_append_by_transfer(fvm_nodal_t *this_nodal,
84 cs_lnum_t n_elements,
85 fvm_element_t type,
86 cs_lnum_t face_index[],
87 cs_lnum_t face_num[],
88 cs_lnum_t vertex_index[],
89 cs_lnum_t vertex_num[],
90 cs_lnum_t parent_element_id[]);
91
92/*----------------------------------------------------------------------------
93 * Append a new section to an existing fvm_nodal mesh, sharing the given
94 * given connectivity and optional parent number arrays with the caller.
95 *
96 * The caller should not destroy or modify the arrays passed to this
97 * function until the nodal mesh is destroyed.
98 *
99 * parameters:
100 * this_nodal <-> nodal mesh structure
101 * n_elements <-- number of elements to add
102 * type <-- type of elements to add
103 * face_index <-- polyhedron -> faces index (O to n-1)
104 * size: n_elements + 1
105 * face_num <-- polyhedron -> face numbers (1 to n, signed,
106 * > 0 for outwards pointing face normal
107 * < 0 for inwards pointing face normal);
108 * size: face_index[n_elements]
109 * vertex_index <-- polygon face -> vertices index (O to n-1)
110 * size: face_index[n_elements]
111 * vertex_num <-- element -> vertex connectivity
112 * parent_element_id <-- element -> parent element id (0 to n-1) if non
113 * trivial (i.e. if element definitions correspond
114 * to a subset of the parent mesh), NULL otherwise
115 *----------------------------------------------------------------------------*/
116
117void
118fvm_nodal_append_shared(fvm_nodal_t *this_nodal,
119 cs_lnum_t n_elements,
120 fvm_element_t type,
121 cs_lnum_t face_index[],
122 cs_lnum_t face_num[],
123 cs_lnum_t vertex_index[],
124 cs_lnum_t vertex_num[],
125 cs_lnum_t parent_element_id[]);
126
127/*----------------------------------------------------------------------------*/
128
130
131#endif /* __FVM_NODAL_APPEND_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
Definition cs_defs.h:335
fvm_element_t
Definition fvm_defs.h:48
void fvm_nodal_append_shared(fvm_nodal_t *this_nodal, cs_lnum_t n_elements, fvm_element_t type, cs_lnum_t face_index[], cs_lnum_t face_num[], cs_lnum_t vertex_index[], cs_lnum_t vertex_num[], cs_lnum_t parent_element_id[])
Definition fvm_nodal_append.cpp:335
void fvm_nodal_append_by_transfer(fvm_nodal_t *this_nodal, cs_lnum_t n_elements, fvm_element_t type, cs_lnum_t face_index[], cs_lnum_t face_num[], cs_lnum_t vertex_index[], cs_lnum_t vertex_num[], cs_lnum_t parent_element_id[])
Definition fvm_nodal_append.cpp:260
