fvm_convert_array.h
1#ifndef __FVM_CONVERT_ARRAY_H__
2#define __FVM_CONVERT_ARRAY_H__
5 * Functions related to the transformation of data arrays for import
6 * or export of meshes and fields.
7 *
8 * All "reasonable" combinations of datatypes are handled here.
9 * (templates would be useful here).
10 *============================================================================*/
11
12/*
13 This file is part of code_saturne, a general-purpose CFD tool.
14
15 Copyright (C) 1998-2025 EDF S.A.
16
17 This program is free software; you can redistribute it and/or modify it under
18 the terms of the GNU General Public License as published by the Free Software
19 Foundation; either version 2 of the License, or (at your option) any later
20 version.
21
22 This program is distributed in the hope that it will be useful, but WITHOUT
23 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
24 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
25 details.
26
27 You should have received a copy of the GNU General Public License along with
28 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
29 Street, Fifth Floor, Boston, MA 02110-1301, USA.
30*/
32/*----------------------------------------------------------------------------*/
34#include "base/cs_defs.h"
37 * Local headers
38 *----------------------------------------------------------------------------*/
40#include "fvm/fvm_defs.h"
41#include "fvm/fvm_nodal.h"
43/*----------------------------------------------------------------------------*/
46
47/*=============================================================================
48 * Macro definitions
50
51/*============================================================================
52 * Type definitions
53 *============================================================================*/
54
55/*=============================================================================
56 * Static global variables
58
59/*=============================================================================
60 * Public function prototypes
61 *============================================================================*/
62
63/*----------------------------------------------------------------------------
64 * Convert an array representation of one type to that of another type, with
65 * possible indirection, interlacing, de-interlacing, or change of data
66 * dimension (i.e. projection or filling extra dimension with zeroes).
67 *
68 * Floating point (real or double) source and destination arrays may be
69 * multidimensional (interlaced or not), but with and integer type
70 * for source or destination, only 1-D arrays are allowed (no use for
71 * integer "vector fields" being currently required or apparent).
72 *
73 * Integer type destination arrays may be converted to floating point
74 * (for output formats with no integer datatype, such as EnSight),
75 * but floating point values may not be converted to integer values
76 * (no use for this operation being currently apparent).
77 *
78 * parameters:
79 * src_dim <-- dimension of source data
80 * src_dim_shift <-- source data dimension shift (start index)
81 * dest_dim <-- destination data dimension (1 if non interlaced)
82 * src_idx_start <-- start index in source data
83 * src_idx_end <-- past-the-end index in source data
84 * src_interlace <-- indicates if source data is interlaced
85 * src_datatype <-- source data type (float, double, or int)
86 * dest_datatype <-- destination data type (float, double, or int)
87 * n_parent_lists <-- number of parent lists (if parent_id != NULL)
88 * parent_id_shift <-- parent id to value array index shifts;
89 * size: n_parent_lists
90 * parent_id <-- if n_parent_lists > 0, parent entity ids
91 * src_data <-- array of source arrays (at least one, with one per
92 * source dimension if non interlaced, times one per
93 * parent list if multiple parent lists, with
94 * x_parent_1, y_parent_1, ..., x_parent_2, ...) order
95 * dest_data --> destination buffer
96 *----------------------------------------------------------------------------*/
97
98void
99fvm_convert_array(const int src_dim,
100 const int src_dim_shift,
101 const int dest_dim,
102 const cs_lnum_t src_idx_start,
103 const cs_lnum_t src_idx_end,
104 const cs_interlace_t src_interlace,
105 const cs_datatype_t src_datatype,
106 const cs_datatype_t dest_datatype,
107 const int n_parent_lists,
108 const cs_lnum_t parent_id_shift[],
109 const cs_lnum_t parent_id[],
110 const void *const src_data[],
111 void *const dest_data);
112
114
116
117#endif /* __FVM_CONVERT_ARRAY_H__ */
cs_datatype_t
Definition cs_defs.h:300
Definition cs_defs.h:542
cs_interlace_t
Definition cs_defs.h:514
Definition cs_defs.h:543
Definition cs_defs.h:335
void fvm_convert_array(const int src_dim, const int src_dim_shift, const int dest_dim, const cs_lnum_t src_idx_start, const cs_lnum_t src_idx_end, const cs_interlace_t src_interlace, const cs_datatype_t src_datatype, const cs_datatype_t dest_datatype, const int n_parent_lists, const cs_lnum_t parent_id_shift[], const cs_lnum_t parent_id[], const void *const src_data[], void *const dest_data)
Definition fvm_convert_array.cpp:1995
