In this section, some specific aspects of the build system are described.
The code_saturne build system is based mostly on the GNU Autotools, and provides a traditional configure, make, make install sequence).
Those tools have their sets of advantages and disadvantages, but are very well documented. A very practical feature, not available in such a natural form in some other build frameworks, is the possibility to provide a quick and complete list of available options using configure --help.
The main solver executable is usually cs_solver, but variants such as nc_solver, or other executables for unit testing are handled in a similar manner.
The main executable is compiled using the Python scripts. When installed or installing, the appropriate code is found in cs_compile.py (under bin in the code sources, and Python package install path in installed code). When building, since the available path structure is different, some methods are overloaded, using code from build-aux/cs_compile_build.py.
To avoid requiring extra steps when releasing a version, which have proved to be error-prone in the past, the code version handling is semi-automatic.
Since it is good practice to provide some form of release notes, and such notes require human intervention, the version number is based on entries available in the NEWS.md file in the top source directory. This is completed by info available from Git, if available. Based on this information, a build_aux/cs_version.py script determines the major, minor, and release numbers,n possibly with an additional Git hash, and a flag indicating whether the version based on Git is further modified (i.e. if there are uncommitted changes).
So when editing the NEWS.md, care must be taken to follow the existing format and naming conventions.
The following logic is also applied in the build_aux/cs_version.py script:
The GNU Autotools provide some nice features, and the code_saturne build system represents a large amount of work over multiple years, but this system is showing its age, and perhaps not evolving well enough to suit current needs.
Worse, these tools have lacked consistent integration from the start. For example, Autoconf allows generating multiple config.h files (such as cs_config.h and cs_config_priv.h), but Automake can only handle one. This has required writing work-arounds. Libtool possibly causes more issues than it solves. And finally, its cross-platform aspects are very limited. So Windows ports are basically limited to the Windows Subsystem for Linux.
Alternatives also have their advantages and disadvantages:
For now, a safe solution seems to be to rewrite some parts of the build system in Python, as is already done in quite a few areas (see files in build-aux), and progressively reduce the reliance on the Autotools (now reduced to Autconf and Automake).
Automake could be replaced by hand-coded Makefiles, using configure to transform Makefile.in templates in the source tree to Makefiles in the build tree (so as to keep the essential possibility of using out-of-tree builds). Dependency rules would need to be generated in a manner similar to that used by Automake, but could be extended to automatic Fortran dependencies (though automatic handling of Fortran binding dependencies would remain tricky).
A first step would be to reduce the number of Makefile templates by using a single Makefile for a whole subtree, rather than recursive Makefiles. As such, a few Makefiles coud be handled at the preprocessor, src, and doc levels, for clarity and to avoid duplicating local rules. Makefiles at an even higher level could be interesting, but to keed the possibility of building only a specific subsystem at a time (useful when developing), specific target names for the various sub-systems would need to be used.
Autoconf could be replaced incrementally by Python code. Most tests and m4 macros would actually be clearer in Python, but some tests from Automake, such as determining C/C++ type sizes even when cross-compiling, may require additional work.
As the preprocessor is an executable, compilation flags for position-independent code are only added for optional plugin code, not the rest of the code. This could be easily changed.
For files which may be compiled into plugins rather than the main libraries (such as src/base/fvm/fvm_to_catalyst.cxx), an associated non-installable library is defined in the matching directory's Automake (Makefile.am) rules, so as to force the file's compilation while still letting Automake handle its dependencies. This is done because Automake only manages rules for programs and libraries, not for individual object files. Another workaround would be to use rules for built (generated) sources.
When not using Libtool, Automake assumes archive (.a) form libraries, so flags for position-independent code are added specifically in the code_saturne build configuration (and can be adapted in config/cs_auto_flags.sh).
To build libraries, a build-aux/cs_link_library.py helper script is used. This script assumes knowledge of some linker options, so to port or update on various (especially non-Linux) systems, it may need to be adapted and extended.
Local targets are then defined so as to build the appropriate libraries, using the matching object (.o), and not library archive (.a) files.
This allows avoiding the use of libtool, while still benefiting from Automake's main features (source file dependency tracking, install targets, ...).
