161 double matrix[3][4]);
174 double matrix[3][4]);
261 const char *dir_name,
262 const char *fmt_name,
263 const char *fmt_opts,
265 bool output_at_start,
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
void cs_stl_mesh_destroy_all(void)
Free all allocated STL mesh structures.
Definition cs_stl.cpp:1169
void cs_stl_mesh_rotate(cs_stl_mesh_t *stl_mesh, double theta, double axis[3], double center[3])
Apply a rotation to a STL mesh structure.
Definition cs_stl.cpp:1558
void cs_stl_set_porosity_seed(cs_stl_mesh_t *stl_mesh, int n_points, cs_real_t *coords)
Set the points outside he STL geometry. Those points will be used as.
Definition cs_stl.cpp:1605
cs_stl_mesh_t * cs_stl_mesh_add(const char *path)
Add a new STL mesh structure.
Definition cs_stl.cpp:1095
void cs_stl_post_add_mesh(cs_stl_mesh_t *stl_mesh)
Associate a STL mesh to the default writer.
Definition cs_stl.cpp:1683
cs_stl_mesh_t * cs_stl_mesh_get_by_name(const char *name)
Return a pointer to a STL mesh based on its name if present.
Definition cs_stl.cpp:1148
void cs_stl_file_read(cs_stl_mesh_t *stl_mesh, const char *path)
Read a binary STL file and store its content in a STL mesh structure.
Definition cs_stl.cpp:1205
void cs_stl_file_write(cs_stl_mesh_t *stl_mesh, const char *path)
Write a binary STL file according to a given STL mesh structure.
Definition cs_stl.cpp:1713
void cs_stl_refine(cs_stl_mesh_t *stl_mesh, int n_ref, int n_add_layer)
Refine the mesh following a given STL mesh.
Definition cs_stl.cpp:2012
void cs_stl_mesh_transform(cs_stl_mesh_t *stl_mesh, double matrix[3][4])
Apply a transformation matrix to a STL mesh structure.
Definition cs_stl.cpp:1459
void cs_stl_mesh_transform_from_init(cs_stl_mesh_t *stl_mesh, double matrix[3][4])
Apply a transformation matrix to a STL mesh structure, but use.
Definition cs_stl.cpp:1496
int cs_stl_post_get_writer_id(void)
Return writer_id used for stl meshes. 0 means unused.
Definition cs_stl.cpp:1623
void cs_stl_intersection(cs_stl_mesh_t *stl_mesh, cs_lnum_t n_input, cs_lnum_t *input_idx, cs_lnum_t *n_selected_cells, cs_lnum_t *selected_cells, cs_lnum_t *tria_in_cell_idx, cs_lnum_t **tria_in_cell_lst, cs_lnum_t *max_size)
Compute intersection between a STL mesh and the main mesh.
Definition cs_stl.cpp:1813
void cs_stl_mesh_translate(cs_stl_mesh_t *stl_mesh, double vector[3])
Apply a translation to a STL mesh structure.
Definition cs_stl.cpp:1530
void cs_stl_mesh_scale(cs_stl_mesh_t *stl_mesh, double scale)
Apply a scaling to a STL mesh structure.
Definition cs_stl.cpp:1580
void cs_stl_post_init_writer(const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int frequency_n, double frequency_t)
Create a new writer that will contains the STL mesh added by the user.
Definition cs_stl.cpp:1640
cs_stl_mesh_info_t * cs_glob_stl_meshes
void cs_stl_compute_porosity(cs_stl_mesh_t *stl_mesh, cs_real_t *porosity, int *indic)
Compute porosity field according to a given STL mesh.
Definition cs_stl.cpp:2160
Definition fvm_writer.h:57
cs_stl_mesh_t ** mesh_list
Definition cs_stl.h:87
int writer_id
Definition cs_stl.h:92
cs_lnum_t n_meshes
Definition cs_stl.h:90
cs_real_3_t * coords_ini
Definition cs_stl.h:65
char header[80]
Definition cs_stl.h:58
cs_lnum_t n_faces
Definition cs_stl.h:60
Definition cs_stl.h:62
bool is_porous
Definition cs_stl.h:74
int n_seeds
Definition cs_stl.h:68
cs_real_t * seed_coords
Definition cs_stl.h:71
char name[20]
Definition cs_stl.h:56
fvm_nodal_t * ext_mesh
Definition cs_stl.h:77
