1#ifndef __CS_PARAM_MUMPS_H__
2#define __CS_PARAM_MUMPS_H__
Definition cs_defs.h:542
Definition cs_defs.h:543
cs_param_mumps_t * cs_param_mumps_create(void)
Create and initialize with the default settings a new structure storing a set of parameters used when...
Definition cs_param_mumps.cpp:87
cs_param_mumps_facto_type_t
type of factorization to consider when using the MUMPS solver to solve a linear system
Definition cs_param_mumps.h:71
@ CS_PARAM_MUMPS_FACTO_LDLT_SYM
This factorization is a Cholesky factorization (L.D.Lt) for general symmetric matrices.
Definition cs_param_mumps.h:74
@ CS_PARAM_MUMPS_N_FACTO_TYPES
Definition cs_param_mumps.h:77
@ CS_PARAM_MUMPS_FACTO_LU
LU factorization is the most generic factorization available with MUMPS. It can handle general matric...
Definition cs_param_mumps.h:73
@ CS_PARAM_MUMPS_FACTO_LDLT_SPD
This factorization is devoted to SPD matrices and corresponds to a Cholesky factorization....
Definition cs_param_mumps.h:75
cs_param_mumps_memory_usage_t
Strategy for the memory usage inside MUMPS.
Definition cs_param_mumps.h:149
@ CS_PARAM_MUMPS_MEMORY_AUTO
Definition cs_param_mumps.h:152
@ CS_PARAM_MUMPS_MEMORY_CONSTRAINED
Definition cs_param_mumps.h:151
@ CS_PARAM_MUMPS_N_MEMORY_USAGES
Definition cs_param_mumps.h:155
@ CS_PARAM_MUMPS_MEMORY_CPU_DRIVEN
Definition cs_param_mumps.h:153
cs_param_mumps_analysis_algo_t
Type of algorithm to consider when using the MUMPS solver to perform the analysis step (renumbering a...
Definition cs_param_mumps.h:119
@ CS_PARAM_MUMPS_ANALYSIS_SCOTCH
Definition cs_param_mumps.h:124
@ CS_PARAM_MUMPS_ANALYSIS_PORD
Definition cs_param_mumps.h:123
@ CS_PARAM_MUMPS_ANALYSIS_PTSCOTCH
Definition cs_param_mumps.h:125
@ CS_PARAM_MUMPS_N_ANALYSIS_ALGOS
Definition cs_param_mumps.h:131
@ CS_PARAM_MUMPS_ANALYSIS_QAMD
Definition cs_param_mumps.h:122
@ CS_PARAM_MUMPS_ANALYSIS_PARMETIS
Definition cs_param_mumps.h:127
@ CS_PARAM_MUMPS_ANALYSIS_AMD
Definition cs_param_mumps.h:121
@ CS_PARAM_MUMPS_ANALYSIS_AUTO
Definition cs_param_mumps.h:129
@ CS_PARAM_MUMPS_ANALYSIS_METIS
Definition cs_param_mumps.h:126
cs_param_mumps_t * cs_param_mumps_copy(const cs_param_mumps_t *mumpsp)
Copy into a new structure the given set of parameters used when calling MUMPS.
Definition cs_param_mumps.cpp:124
void cs_param_mumps_log(const char *name, const cs_param_mumps_t *mumpsp)
Log the structure storing the set of parameters used with MUMPS.
Definition cs_param_mumps.cpp:153
Set of parameters to specify additional options to MUMPS For more advanced settings,...
Definition cs_param_mumps.h:166
cs_param_mumps_facto_type_t facto_type
Definition cs_param_mumps.h:180
double blr_threshold
Definition cs_param_mumps.h:188
double mem_coef
Definition cs_param_mumps.h:195
int ir_steps
Definition cs_param_mumps.h:204
int block_analysis
Definition cs_param_mumps.h:201
cs_param_mumps_memory_usage_t mem_usage
Definition cs_param_mumps.h:181
bool is_single
Definition cs_param_mumps.h:183
cs_param_mumps_analysis_algo_t analysis_algo
Definition cs_param_mumps.h:179
bool keep_ordering
Definition cs_param_mumps.h:199
bool advanced_optim
Definition cs_param_mumps.h:185
