cs_mesh_intersect.h
1#ifndef __CS_MESH_INTERSECT_H__
2#define __CS_MESH_INTERSECT_H__
5 * Postprocessing utility functions.
31 * Local headers
34#include "base/cs_defs.h"
41 * Type Definitions
45 * Global variables
49 * Public function prototypes
51
52/*----------------------------------------------------------------------------*/
77/*----------------------------------------------------------------------------*/
78
79void
81 cs_lnum_t *n_cells,
82 cs_lnum_t **cell_ids);
83
84/*----------------------------------------------------------------------------*/
114
115void
117 cs_lnum_t n_points,
118 cs_lnum_t *n_cells,
119 cs_lnum_t **cell_ids,
120 cs_real_t **seg_c_len,
121 cs_real_3_t **seg_c_cen );
122
123/*----------------------------------------------------------------------------*/
143
144void
146 const cs_real_t point_coords[],
147 cs_real_t min_fraction,
148 cs_lnum_t **seg_cell_idx,
149 cs_lnum_t **seg_cell,
150 cs_real_t **seg_cell_fraction);
151
152/*----------------------------------------------------------------------------*/
153
155
156#endif /* __CS_MESH_INTERSECT_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
void cs_mesh_intersect_polyline_cell_select(void *input, cs_lnum_t n_points, cs_lnum_t *n_cells, cs_lnum_t **cell_ids, cs_real_t **seg_c_len, cs_real_3_t **seg_c_cen)
Select cells cut by a line composed of segments.
Definition cs_mesh_intersect.cpp:435
void cs_mesh_intersect_segment_cell_select(void *input, cs_lnum_t *n_cells, cs_lnum_t **cell_ids)
Select cells cut by a given segment.
Definition cs_mesh_intersect.cpp:268
void cs_mesh_intersect_polyline_map(cs_lnum_t n_points, const cs_real_t point_coords[], cs_real_t min_fraction, cs_lnum_t **seg_cell_idx, cs_lnum_t **seg_cell, cs_real_t **seg_cell_fraction)
Map a polyline of segments to the local mesh.
Definition cs_mesh_intersect.cpp:796
