cs_matrix_spmv_cuda.h
1#ifndef __CS_MATRIX_SPMV_CUDA_H__
2#define __CS_MATRIX_SPMV_CUDA_H__
5 * Sparse Matrix-vector multiplication kernels using CUDA.
31 * Local headers
34#include "base/cs_defs.h"
45/*----------------------------------------------------------------------------*/
46
48 * Public CUDA kernel prototypes
50
51#if defined(__CUDACC__)
52
53#endif /* defined(__CUDACC__) */
54
55/*============================================================================
56 * Public function prototypes
58
59/*----------------------------------------------------------------------------*/
65/*----------------------------------------------------------------------------*/
66
67void
69
70#if defined(__CUDACC__)
71
72/*----------------------------------------------------------------------------*/
83/*----------------------------------------------------------------------------*/
84
85void
86cs_matrix_spmv_cuda_set_stream(cudaStream_t stream);
87
88/*----------------------------------------------------------------------------*/
95
96cudaStream_t
97cs_matrix_spmv_cuda_get_stream(void);
98
99#endif /* defined(__CUDACC__) */
100
101/*----------------------------------------------------------------------------*/
111/*----------------------------------------------------------------------------*/
112
113void
115 bool exclude_diag,
116 bool sync,
117 cs_real_t d_x[],
118 cs_real_t d_y[]);
119
120/*----------------------------------------------------------------------------*/
130/*----------------------------------------------------------------------------*/
131
132void
134 bool exclude_diag,
135 bool sync,
136 cs_real_t d_x[],
137 cs_real_t d_y[]);
138
139/*----------------------------------------------------------------------------*/
149/*----------------------------------------------------------------------------*/
150
151void
153 bool exclude_diag,
154 bool sync,
155 cs_real_t d_x[],
156 cs_real_t d_y[]);
157
158/*----------------------------------------------------------------------------*/
168/*----------------------------------------------------------------------------*/
169
170void
172 bool exclude_diag,
173 bool sync,
174 cs_real_t d_x[],
175 cs_real_t d_y[]);
176
177/*----------------------------------------------------------------------------*/
187/*----------------------------------------------------------------------------*/
188
189void
191 bool exclude_diag,
192 bool sync,
193 cs_real_t d_x[],
194 cs_real_t d_y[]);
195
196/*----------------------------------------------------------------------------*/
207/*----------------------------------------------------------------------------*/
208
209void
211 bool exclude_diag,
212 bool sync,
213 cs_real_t d_x[],
214 cs_real_t d_y[]);
215
216#if defined(HAVE_CUSPARSE_GENERIC_API)
217
218/*----------------------------------------------------------------------------*/
234/*----------------------------------------------------------------------------*/
235
236void
237cs_matrix_spmv_cuda_msr_b_cusparse(cs_matrix_t *matrix,
238 bool exclude_diag,
239 bool sync,
240 cs_real_t d_x[],
241 cs_real_t d_y[]);
242
243#endif /* defined(HAVE_CUSPARSE_GENERIC_API) */
244
245/*----------------------------------------------------------------------------*/
261/*----------------------------------------------------------------------------*/
262
263void
265 bool exclude_diag,
266 bool sync,
267 cs_real_t d_x[],
268 cs_real_t d_y[]);
269
270/*----------------------------------------------------------------------------*/
271
273
274#endif /* __CS_MATRIX_SPMV__CUDA_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_matrix.h:110
void cs_matrix_spmv_cuda_msr_bb_cusparse(cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
Matrix.vector product y = A.x with MSR matrix, block cuSPARSE version.
void cs_matrix_spmv_cuda_csr(cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
Matrix.vector product y = A.x with CSR matrix, scalar CUDA version.
void cs_matrix_spmv_cuda_csr_cusparse(cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
Matrix.vector product y = A.x with CSR matrix, scalar cuSPARSE version.
void cs_matrix_spmv_cuda_native(cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
Matrix.vector product y = A.x with MSR matrix, scalar CUDA version.
void cs_matrix_spmv_cuda_finalize(void)
Finalize CUDA matrix API.
void cs_matrix_spmv_cuda_msr_cusparse(cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
Matrix.vector product y = A.x with MSR matrix, scalar cuSPARSE version.
void cs_matrix_spmv_cuda_msr(cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
void cs_matrix_spmv_cuda_msr_b(cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
Matrix.vector product y = A.x with MSR matrix, block diagonal CUDA version.
