cs_macfb_monolithic_sles.h
1#ifndef __CS_MACFB_MONOLITHIC_SLES_H__
2#define __CS_MACFB_MONOLITHIC_SLES_H__
5 * Functions dedicated to the linear algebra settings and operations in case
6 * of MAC face-based schemes with a monolithic velocity-pressure coupling
7 *============================================================================*/
8
9/*
10 This file is part of code_saturne, a general-purpose CFD tool.
11
12 Copyright (C) 1998-2025 EDF S.A.
13
14 This program is free software; you can redistribute it and/or modify it under
15 the terms of the GNU General Public License as published by the Free Software
16 Foundation; either version 2 of the License, or (at your option) any later
17 version.
18
19 This program is distributed in the hope that it will be useful, but WITHOUT
20 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
21 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
22 details.
23
24 You should have received a copy of the GNU General Public License along with
25 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
26 Street, Fifth Floor, Boston, MA 02110-1301, USA.
27*/
28
29/*----------------------------------------------------------------------------*/
30
31#include "base/cs_defs.h"
32
33/*----------------------------------------------------------------------------
34 * Standard C library headers
35 *----------------------------------------------------------------------------*/
36
37/*----------------------------------------------------------------------------
38 * Local headers
39 *----------------------------------------------------------------------------*/
43/*----------------------------------------------------------------------------*/
46
48 * Macro definitions
50
51/*============================================================================
52 * Type definitions
53 *============================================================================*/
54
55/*============================================================================
56 * Public function prototypes
58
59/*----------------------------------------------------------------------------*/
67/*----------------------------------------------------------------------------*/
68
70 const cs_cdo_connect_t *connect,
71 const cs_cdo_quantities_t *quant);
72
73/*----------------------------------------------------------------------------*/
83/*----------------------------------------------------------------------------*/
84
85void
87 const cs_param_saddle_t *saddlep,
89
90/*----------------------------------------------------------------------------*/
100/*----------------------------------------------------------------------------*/
101
103 const cs_param_saddle_t *saddlep,
105
106/*----------------------------------------------------------------------------*/
120/*----------------------------------------------------------------------------*/
121
123 cs_saddle_solver_t *solver,
124 cs_real_t *u_f,
125 cs_real_t *p_c);
126
127/*----------------------------------------------------------------------------*/
143
145 cs_saddle_solver_t *solver,
146 cs_real_t *u_f,
147 cs_real_t *p_c);
148
149/*----------------------------------------------------------------------------*/
165/*----------------------------------------------------------------------------*/
166
168 cs_saddle_solver_t *solver,
169 cs_real_t *u_f,
170 cs_real_t *p_c);
171
172/*----------------------------------------------------------------------------*/
186/*----------------------------------------------------------------------------*/
187
189 cs_saddle_solver_t *solver,
190 cs_real_t *u_f,
191 cs_real_t *p_c);
192
193/*----------------------------------------------------------------------------*/
194
196
197#endif /* __CS_MACFB_MONOLITHIC_SLES_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Structures and function pointers useful to build and solve the Navier-Stokes equations with MAC face-...
struct _macfb_monolithic_t cs_macfb_monolithic_t
Definition cs_macfb_monolithic_priv.h:75
int cs_macfb_monolithic_sles_block_krylov(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Solve a linear system arising from the discretization of the Navier-Stokes equation with a MAC face-b...
Definition cs_macfb_monolithic_sles.cpp:1135
void cs_macfb_monolithic_sles_init_solver(const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_macfb_monolithic_t *sc)
Define the saddle solver and its context for a MAC-Fb scheme solving the Navier-Stokes equation using...
Definition cs_macfb_monolithic_sles.cpp:886
void cs_macfb_monolithic_sles_init_sharing(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Set pointers to shared structures.
Definition cs_macfb_monolithic_sles.cpp:737
int cs_macfb_monolithic_sles_alu(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithi...
Definition cs_macfb_monolithic_sles.cpp:1035
int cs_macfb_monolithic_sles_uzawa_cg(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition cs_macfb_monolithic_sles.cpp:1405
int cs_macfb_monolithic_sles_gkb_inhouse(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition cs_macfb_monolithic_sles.cpp:1304
void cs_macfb_monolithic_sles_init_system_helper(const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_macfb_monolithic_t *sc)
Define the system helper for a MAC-Fb scheme solving the Navier-Stokes equation using a monolithic ap...
Definition cs_macfb_monolithic_sles.cpp:763
Definition mesh.f90:26
Definition cs_cdo_connect.h:61
Definition cs_cdo_quantities.h:145
Definition cs_mesh.h:85
Definition cs_navsto_param.h:263
Structure storing all metadata related to the resolution of a saddle-point linear system....
Definition cs_param_saddle.h:273
Definition cs_saddle_solver.h:89
