Radiative thermal transfers in semi-transparent gray media
Initialization of the radiation main parameters
The main radiation parameters can be initialized in the GUI or in the cs_user_radiative_transfer_parameters user function (see Initialization examples). In the GUI, under the heading Thermal models, when one of the two thermal radiative transfers models is selected, see Figure 1 additional items appear. The user is asked to choose the number of directions for angular discretization, to define the absorption coefficient and specify if the radiative calculation is restarted from a checkpoint or not; see Figure 1 and Figure 3. When Advanced options is selected for both models Figure 2 and Figure 4 appear, the user must fill the resolution frequency and verbosity levels. In addition, the activation of the radiative transfer leads to the creation of a Surface solution control item under the heading Calculation control, see Figure 5, where radiative transfer variables can be selected to appear in the output log.
Warning
when a calculation is run using a specific physics module, this first heading must not be completed. The radiation module is then activated or not, according to the parameter file related to the considered specific physics.
Radiative transfer boundary conditions
These conditions can be defined with the GUI or by programming the cs_user_radiative_transfer_bcs function; see boundary examples. In the GUI, when one of the Radiative transfers options is selected in Figure 1 and Boundary zones is defined in Mesh, it activates specific boundary conditions each time a Wall is defined, see Figure 6. The user can then choose between 3 cases. The parameters that must be specified are displayed for one of them in Figure 7.
Absorption coefficient of the medium, boundary conditions for the luminance, and calculation of the net radiative flux
When the absorption coefficient is not constant, the cs_user_rad_transfer_absorption functionis called at each time step. It is composed of three parts. In the first one, the user must provide the absorption coefficient of the medium in the array CK, for each cell of the fluid mesh. By default, the absorption coefficient of the medium is 0, which corresponds to a transparent medium. For more detail see Absorption
Warning
When a specific physical model is activated, it is forbidden to set the absorption coefficient in this function. In this case, the coefficient is either calculated automatically, or provided by the user via a thermo-chemical parameter file (dp_C3P or dp_C3PSJ for gas combustion, and dp_FCP for pulverized coal combustion).
Radiative transfers - parameters of the DO method
Radiative transfers - advanced parameters of the DO method
Radiative transfers - parameters of the P-1 model
Radiative transfers - advanced parameters of the P-1 model
Calculation control - Radiative transfers post-processing output
Boundary conditions - choice of wall thermal radiative transfers
Boundary conditions - example of wall thermal radiative transfer
