8.3
fvm_triangulate.h
1#ifndef __FVM_TRIANGULATE_H__
2#define __FVM_TRIANGULATE_H__
5 * Triangulation of a polygon
30#include "cs_defs.h"
33 * Local headers
36#include "fvm_defs.h"
42/*=============================================================================
43 * Macro definitions
45
47 * Type definitions
49
50/*
51 * Pointer to structure maintaining the state of the current triangulation;
52 * the structure itself is private.
53 */
54
55typedef struct _fvm_triangulate_state_t fvm_triangulate_state_t;
56
57/*
58 * Describe how the resulting triangle connectivity is defined.
59 */
60
61typedef enum {
62
63 FVM_TRIANGULATE_MESH_DEF, /* Definition by mesh vertex numbers */
64 FVM_TRIANGULATE_ELT_DEF /* Definition by local (element) vertex
65 position (1 to n) */
66
68
69/*=============================================================================
70 * Static global variables
71 *============================================================================*/
72
73/*=============================================================================
74 * Public function prototypes
75 *============================================================================*/
76
77/*----------------------------------------------------------------------------
78 * Create a structure necessary to the polygon triangulation algorithm.
79 *
80 * parameters:
81 * n_vertices_max <-- maximum expected number of vertices per polygon.
82 *
83 * returns:
84 * pointer to polygon triangulation state structure.
85 *----------------------------------------------------------------------------*/
86
88fvm_triangulate_state_create(const int n_vertices_max);
89
90/*----------------------------------------------------------------------------
91 * Destroy a structure necessary to the polygon triangulation algorithm.
92 *
93 * parameters:
94 * this_state <-> pointer to structure that should be destroyed.
95 *
96 * returns:
97 * null pointer.
98 *----------------------------------------------------------------------------*/
99
102
103/*----------------------------------------------------------------------------
104 * Triangulate a polygonal face.
105 *
106 * For a polygon with n vertices, we should obtain a triangluation with
107 * (n-2) triangles and (2n-3) edges. If the polygon_vertices argument
108 * is NULL, 1, 2, ...,n local numbering is implied.
109 *
110 * parameters:
111 * dim <-- spatial dimension (2 or 3).
112 * base <-- base numbering (usually 0 or 1)
113 * n_vertices <-- number of vertices defining the polygon.
114 * coords <-- coordinates of the triangulation's vertices.
115 * parent_vertex_id <-- optional indirection to vertex coordinates
116 * (0 to n-1).
117 * polygon_vertices <-- polygon connectivity; size: n_vertices or empty.
118 * mode <-- triangles connectivity by vertex number or
119 * polygon vertex index.
120 * triangle_vertices --> triangles connectivity;
121 * size: (n_vertices - 2) * 3.
122 * state <-> associated triangulation state structure.
123 *
124 * returns:
125 * number of resulting triangles.
126 *----------------------------------------------------------------------------*/
127
128int
130 int base,
131 int n_vertices,
132 const cs_coord_t coords[],
133 const cs_lnum_t parent_vertex_id[],
134 const cs_lnum_t polygon_vertices[],
136 cs_lnum_t triangle_vertices[],
137 fvm_triangulate_state_t *const state);
138
139/*----------------------------------------------------------------------------
140 * Triangulate a quadrangle.
141 *
142 * A convex quadrangle is divided into two triangles along its shortest
143 * diagonal. A non-convex quadrangle may only be divided along the diagonal
144 * which lies inside the quadrangle.
145 *
146 * If the quadrangle_vertices argument is NULL, 1, 2, ...,n local numbering
147 * is implied.
148 *
149 * parameters:
150 * dim <-- spatial dimension (2 or 3).
151 * base <-- base numbering (usually 0 or 1)
152 * coords <-- coordinates of the triangulation's vertices.
153 * parent_vertex_id <-- optional indirection to vertex coordinates
154 * (0 to n-1).
155 * quadrangle_vertices <-- polygon connectivity; size: n_vertices or empty.
156 * triangle_vertices --> triangles connectivity; size: 2 * 3.
157 *
158 * returns:
159 * number of resulting triangles.
160 *----------------------------------------------------------------------------*/
161
162int
164 int base,
165 const cs_coord_t coords[],
166 const cs_lnum_t parent_vertex_id[],
167 const cs_lnum_t quadrangle_vertices[],
168 cs_lnum_t triangle_vertices[]);
169
170/*----------------------------------------------------------------------------*/
171
173
174#endif /* __FVM_TRIANGULATE_H__ */
Definition: cs_defs.h:542
double cs_coord_t
Definition: cs_defs.h:340
Definition: cs_defs.h:543
Definition: cs_defs.h:335
fvm_triangulate_state_t * fvm_triangulate_state_create(const int n_vertices_max)
Definition: fvm_triangulate.cpp:986
int fvm_triangulate_polygon(int dim, int base, int n_vertices, const cs_coord_t coords[], const cs_lnum_t parent_vertex_id[], const cs_lnum_t polygon_vertices[], fvm_triangulate_def_t mode, cs_lnum_t triangle_vertices[], fvm_triangulate_state_t *const state)
Definition: fvm_triangulate.cpp:1077
Definition: fvm_triangulate.h:55
fvm_triangulate_state_t * fvm_triangulate_state_destroy(fvm_triangulate_state_t *this_state)
Definition: fvm_triangulate.cpp:1032
int fvm_triangulate_quadrangle(int dim, int base, const cs_coord_t coords[], const cs_lnum_t parent_vertex_id[], const cs_lnum_t quadrangle_vertices[], cs_lnum_t triangle_vertices[])
Definition: fvm_triangulate.cpp:1293
Definition: fvm_triangulate.h:61
@ FVM_TRIANGULATE_MESH_DEF
Definition: fvm_triangulate.h:63
@ FVM_TRIANGULATE_ELT_DEF
Definition: fvm_triangulate.h:64
