8.3
fvm_to_ensight.h
1#ifndef __FVM_TO_ENSIGHT_H__
2#define __FVM_TO_ENSIGHT_H__
5 * Write a nodal representation associated with a mesh and associated
6 * variables to EnSight Gold files
7 *============================================================================*/
8
9/*
10 This file is part of code_saturne, a general-purpose CFD tool.
11
12 Copyright (C) 1998-2024 EDF S.A.
13
14 This program is free software; you can redistribute it and/or modify it under
15 the terms of the GNU General Public License as published by the Free Software
16 Foundation; either version 2 of the License, or (at your option) any later
17 version.
18
19 This program is distributed in the hope that it will be useful, but WITHOUT
20 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
21 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
22 details.
23
24 You should have received a copy of the GNU General Public License along with
25 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
26 Street, Fifth Floor, Boston, MA 02110-1301, USA.
27*/
28
29/*----------------------------------------------------------------------------*/
30
31#include "cs_defs.h"
32
33/*----------------------------------------------------------------------------
34 * Local headers
35 *----------------------------------------------------------------------------*/
36
37#include "fvm_defs.h"
38#include "fvm_nodal.h"
39#include "fvm_writer.h"
45/*=============================================================================
46 * Macro definitions
48
50 * Type definitions
52
53/*=============================================================================
54 * Public function prototypes
55 *============================================================================*/
56
57/*----------------------------------------------------------------------------
58 * Initialize FVM to EnSight Gold file writer.
59 *
60 * Options are:
61 * text output text files
62 * binary output binary files (default)
63 * big_endian force binary files to big-endian
64 * discard_polygons do not output polygons or related values
65 * discard_polyhedra do not output polyhedra or related values
66 * divide_polygons tesselate polygons with triangles
67 * divide_polyhedra tesselate polyhedra with tetrahedra and pyramids
68 * (adding a vertex near each polyhedron's center)
69 *
70 * parameters:
71 * name <-- base output case name.
72 * options <-- whitespace separated, lowercase options list
73 * time_dependecy <-- indicates if and how meshes will change with time
74 * comm <-- associated MPI communicator.
75 *
76 * returns:
77 * pointer to opaque EnSight Gold writer structure.
78 *----------------------------------------------------------------------------*/
79
80#if defined(HAVE_MPI)
81
82void *
83fvm_to_ensight_init_writer(const char *name,
84 const char *path,
85 const char *options,
86 fvm_writer_time_dep_t time_dependency,
87 MPI_Comm comm);
88
89#else
90
91void *
92fvm_to_ensight_init_writer(const char *name,
93 const char *path,
94 const char *options,
95 fvm_writer_time_dep_t time_dependency);
96
97#endif
98
99/*----------------------------------------------------------------------------
100 * Finalize FVM to EnSight Gold file writer.
101 *
102 * parameters:
103 * this_writer_p <-- pointer to opaque Ensight Gold writer structure.
104 *
105 * returns:
106 * null pointer.
107 *----------------------------------------------------------------------------*/
108
109void *
110fvm_to_ensight_finalize_writer(void *this_writer_p);
111
112/*----------------------------------------------------------------------------
113 * Associate new time step with an EnSight geometry.
114 *
115 * parameters:
116 * this_writer_p <-- pointer to associated writer
117 * time_step <-- time step number
118 * time_value <-- time_value number
119 *----------------------------------------------------------------------------*/
120
121void
122fvm_to_ensight_set_mesh_time(void *this_writer_p,
123 const int time_step,
124 const double time_value);
125
126/*----------------------------------------------------------------------------
127 * Indicate if a elements of a given type in a mesh associated to a given
128 * EnSight Gold file writer need to be tesselated.
129 *
130 * parameters:
131 * this_writer_p <-- pointer to associated writer
132 * mesh <-- pointer to nodal mesh structure that should be written
133 * element_type <-- element type we are interested in
134 *
135 * returns:
136 * 1 if tesselation of the given element type is needed, 0 otherwise
137 *----------------------------------------------------------------------------*/
138
139int
140fvm_to_ensight_needs_tesselation(void *this_writer_p,
141 const fvm_nodal_t *mesh,
142 fvm_element_t element_type);
143
144/*----------------------------------------------------------------------------
145 * Write nodal mesh to a an EnSight Gold file
146 *
147 * parameters:
148 * this_writer_p <-- pointer to associated writer.
149 * mesh <-- pointer to nodal mesh structure that should be written.
150 *----------------------------------------------------------------------------*/
151
152void
153fvm_to_ensight_export_nodal(void *this_writer_p,
154 const fvm_nodal_t *mesh);
155
156/*----------------------------------------------------------------------------
157 * Write field associated with a nodal mesh to an EnSight Gold file.
158 *
159 * Assigning a negative value to the time step indicates a time-independent
160 * field (in which case the time_value argument is unused).
161 *
162 * parameters:
163 * this_writer_p <-- pointer to associated writer
164 * mesh <-- pointer to associated nodal mesh structure
165 * name <-- variable name
166 * location <-- variable definition location (nodes or elements)
167 * dimension <-- variable dimension (0: constant, 1: scalar,
168 * 3: vector, 6: sym. tensor, 9: asym. tensor)
169 * interlace <-- indicates if variable in memory is interlaced
170 * n_parent_lists <-- indicates if variable values are to be obtained
171 * directly through the local entity index (when 0) or
172 * through the parent entity numbers (when 1 or more)
173 * parent_num_shift <-- parent number to value array index shifts;
174 * size: n_parent_lists
175 * datatype <-- indicates the data type of (source) field values
176 * time_step <-- number of the current time step
177 * time_value <-- associated time value
178 * field_values <-- array of associated field value arrays
179 *----------------------------------------------------------------------------*/
180
181void
182fvm_to_ensight_export_field(void *this_writer_p,
183 const fvm_nodal_t *mesh,
184 const char *name,
185 fvm_writer_var_loc_t location,
186 int dimension,
187 cs_interlace_t interlace,
188 int n_parent_lists,
189 const cs_lnum_t parent_num_shift[],
190 cs_datatype_t datatype,
191 int time_step,
192 double time_value,
193 const void *const field_values[]);
194
195/*----------------------------------------------------------------------------*/
196
198
199#endif /* __FVM_TO_ENSIGHT_H__ */
cs_datatype_t
Definition: cs_defs.h:300
Definition: cs_defs.h:542
cs_interlace_t
Definition: cs_defs.h:514
Definition: cs_defs.h:543
Definition: cs_defs.h:335
fvm_element_t
Definition: fvm_defs.h:48
void * fvm_to_ensight_init_writer(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency)
Definition: fvm_to_ensight.cpp:2550
void * fvm_to_ensight_finalize_writer(void *this_writer_p)
Definition: fvm_to_ensight.cpp:2669
void fvm_to_ensight_set_mesh_time(void *this_writer_p, const int time_step, const double time_value)
Definition: fvm_to_ensight.cpp:2693
int fvm_to_ensight_needs_tesselation(void *this_writer_p, const fvm_nodal_t *mesh, fvm_element_t element_type)
Definition: fvm_to_ensight.cpp:2719
void fvm_to_ensight_export_nodal(void *this_writer_p, const fvm_nodal_t *mesh)
Definition: fvm_to_ensight.cpp:2766
void fvm_to_ensight_export_field(void *this_writer_p, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition: fvm_to_ensight.cpp:3023
Definition: fvm_writer.h:57
Definition: fvm_writer.h:69
Definition: mesh.f90:26
