8.3
fvm_to_catalyst.h
1#ifndef __FVM_TO_CATALYST_H__
2#define __FVM_TO_CATALYST_H__
4#if defined(HAVE_CATALYST)
5
6/*============================================================================
7 * Write a nodal representation associated with a mesh and associated
8 * variables to Catalyst objects
9 *============================================================================*/
11/*
12 This file is part of code_saturne, a general-purpose CFD tool.
13
14 Copyright (C) 1998-2024 EDF S.A.
15
16 This program is free software; you can redistribute it and/or modify it under
17 the terms of the GNU General Public License as published by the Free Software
18 Foundation; either version 2 of the License, or (at your option) any later
19 version.
20
21 This program is distributed in the hope that it will be useful, but WITHOUT
22 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
23 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
24 details.
25
26 You should have received a copy of the GNU General Public License along with
27 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
28 Street, Fifth Floor, Boston, MA 02110-1301, USA.
29*/
30
31/*----------------------------------------------------------------------------*/
32
33#include "cs_defs.h"
34
35/*----------------------------------------------------------------------------
36 * Local headers
37 *----------------------------------------------------------------------------*/
38
39#include "fvm_defs.h"
40#include "fvm_nodal.h"
41#include "fvm_writer.h"
43/*----------------------------------------------------------------------------*/
46
47/*=============================================================================
48 * Macro definitions
50
51/*============================================================================
52 * Type definitions
53 *============================================================================*/
54
55/*=============================================================================
56 * Public function prototypes
58
59/*----------------------------------------------------------------------------
60 * Initialize FVM to Catalyst object writer.
61 *
62 * Options are:
63 * private_comm use private MPI communicator (default: false)
64 * names=<fmt> use same naming rules as <fmt> format
65 * (default: ensight)
66 * input_name=<name> define input name (default: writer name)
67 *
68 * parameters:
69 * name <-- base output case name.
70 * options <-- whitespace separated, lowercase options list
71 * time_dependecy <-- indicates if and how meshes will change with time
72 * comm <-- associated MPI communicator.
73 *
74 * returns:
75 * pointer to opaque Catalyst writer structure.
76 *----------------------------------------------------------------------------*/
77
78#if defined(HAVE_MPI)
79
80void *
81fvm_to_catalyst_init_writer(const char *name,
82 const char *path,
83 const char *options,
84 fvm_writer_time_dep_t time_dependency,
85 MPI_Comm comm);
86
87#else
88
89void *
90fvm_to_catalyst_init_writer(const char *name,
91 const char *path,
92 const char *options,
93 fvm_writer_time_dep_t time_dependency);
94
95#endif
96
97/*----------------------------------------------------------------------------
98 * Finalize FVM to Catalyst object writer.
99 *
100 * parameters:
101 * this_writer_p <-- pointer to opaque Catalyst writer structure.
102 *
103 * returns:
104 * null pointer.
105 *----------------------------------------------------------------------------*/
106
107void *
108fvm_to_catalyst_finalize_writer(void *this_writer_p);
109
110/*----------------------------------------------------------------------------
111 * Associate new time step with a Catalyst geometry.
112 *
113 * parameters:
114 * this_writer_p <-- pointer to associated writer
115 * time_step <-- time step number
116 * time_value <-- time_value number
117 *----------------------------------------------------------------------------*/
118
119void
120fvm_to_catalyst_set_mesh_time(void *this_writer_p,
121 int time_step,
122 double time_value);
123
124/*----------------------------------------------------------------------------
125 * Write nodal mesh to a a Catalyst object
126 *
127 * parameters:
128 * this_writer_p <-- pointer to associated writer.
129 * mesh <-- pointer to nodal mesh structure that should be written.
130 *----------------------------------------------------------------------------*/
131
132void
133fvm_to_catalyst_export_nodal(void *this_writer_p,
134 const fvm_nodal_t *mesh);
135
136/*----------------------------------------------------------------------------
137 * Write data to the MultiBlock aimed to be CoProcessed
138 *
139 * parameters:
140 * this_writer_p <-- pointer to associated writer
141 * ugrid <-- pointer to the vtkUnstructuredGrid
142 *----------------------------------------------------------------------------*/
143
144void
145fvm_to_catalyst_export_field(void *this_writer_p,
146 const fvm_nodal_t *mesh,
147 const char *name,
148 fvm_writer_var_loc_t location,
149 int dimension,
150 cs_interlace_t interlace,
151 int n_parent_lists,
152 const cs_lnum_t parent_num_shift[],
153 cs_datatype_t datatype,
154 int time_step,
155 double time_value,
156 const void *const field_values[]);
157
158/*----------------------------------------------------------------------------
159 * Flush files associated with a given writer.
160 *
161 * In this case, the effective call to coprocessing is done.
162 *
163 * parameters:
164 * this_writer_p <-- pointer to associated writer
165 *----------------------------------------------------------------------------*/
166
167void
168fvm_to_catalyst_flush(void *this_writer_p);
169
170/*----------------------------------------------------------------------------*/
171
173
174#endif /* defined(HAVE_CATALYST) */
175
176#endif /* __FVM_TO_CATALYST_H__ */
cs_datatype_t
Definition: cs_defs.h:300
Definition: cs_defs.h:542
cs_interlace_t
Definition: cs_defs.h:514
Definition: cs_defs.h:543
Definition: cs_defs.h:335
Definition: fvm_writer.h:57
Definition: fvm_writer.h:69
Definition: mesh.f90:26
