8.3
fvm_nodal_project.h
1#ifndef __FVM_NODAL_PROJECT_H__
2#define __FVM_NODAL_PROJECT_H__
5 * Projection of nodal sections associated with a mesh
30#include "cs_defs.h"
33 * Local headers
36#include "fvm_defs.h"
42/*=============================================================================
43 * Public function prototypes
45
46/*----------------------------------------------------------------------------
47 * Project an extruded mesh to its base plane.
48 *
49 * This is currently only possible for 2D element topologies.
50 *
51 * parameters:
52 * this_nodal <-> pointer to structure that should be cut in edges
53 * chosen_axis <-- indicate which axis is selected to extract edges
54 * error_count --> number of triangulation errors counter (optional)
55 *----------------------------------------------------------------------------*/
56
57void
58fvm_nodal_project(fvm_nodal_t *this_nodal,
59 int chosen_axis,
60 cs_lnum_t *error_count);
61
62/*----------------------------------------------------------------------------
63 * Reduce the spatial dimension of a mesh, discarding the last coordinate
64 * component.
65 *
66 * The mesh's spatial dimension is reduced by 1.
67 *
68 * parameters:
69 * this_nodal <-> pointer to structure that projected
70 * matrix <-- projection matrix
71 * 3D -> 2D: (a11, a12, a13, a21, a22, a23)
72 * 2D -> 1D: (a11, a12)
73 *----------------------------------------------------------------------------*/
74
75void
76fvm_nodal_project_coords(fvm_nodal_t *this_nodal,
77 double matrix[]);
78
79/*----------------------------------------------------------------------------*/
80
82
83#endif /* __FVM_NODAL_PROJECT_H__ */
Definition: cs_defs.h:542
Definition: cs_defs.h:543
Definition: cs_defs.h:335
void fvm_nodal_project(fvm_nodal_t *this_nodal, int chosen_axis, cs_lnum_t *error_count)
Definition: fvm_nodal_project.cpp:412
void fvm_nodal_project_coords(fvm_nodal_t *this_nodal, double matrix[])
Definition: fvm_nodal_project.cpp:505
