8.3
fvm_nodal_order.h
1#ifndef __FVM_NODAL_ORDER_H__
2#define __FVM_NODAL_ORDER_H__
5 * Ordering of nodal mesh entity lists and connectivity
30#include "cs_defs.h"
33 * Local headers
36#include "fvm_defs.h"
42/*=============================================================================
43 * Macro definitions
45
47 * Type definitions
49
50/*=============================================================================
51 * Static global variables
53
54/*=============================================================================
55 * Public function prototypes
57
58/*----------------------------------------------------------------------------
59 * Locally order cells and associated connectivity for a nodal mesh
60 *
61 * parameters:
62 * this_nodal <-- pointer to nodal mesh structure.
63 * parent_global_number <-- global numbers of parent cells (if NULL, a
64 * default 1 to n numbering is considered).
65 *----------------------------------------------------------------------------*/
66
67void
68fvm_nodal_order_cells(fvm_nodal_t *this_nodal,
69 const cs_gnum_t parent_global_number[]);
70
71/*----------------------------------------------------------------------------
72 * Locally order faces and associated connectivity for a nodal mesh
73 *
74 * parameters:
75 * this_nodal <-- pointer to nodal mesh structure.
76 * parent_global_number <-- global numbers of parent faces (if NULL, a
77 * default 1 to n numbering is considered).
78 *----------------------------------------------------------------------------*/
79
80void
81fvm_nodal_order_faces(fvm_nodal_t *this_nodal,
82 const cs_gnum_t parent_global_number[]);
83
84/*----------------------------------------------------------------------------
85 * Locally order vertices and update connectivity for a nodal mesh
86 *
87 * parameters:
88 * this_nodal <-- pointer to nodal mesh structure.
89 * parent_global_number <-- global numbers of parent vertices (if NULL, a
90 * default 1 to n numbering is considered).
91 *----------------------------------------------------------------------------*/
92
93void
94fvm_nodal_order_vertices(fvm_nodal_t *this_nodal,
95 const cs_gnum_t parent_global_number[]);
96
97/*----------------------------------------------------------------------------*/
98
100
101#endif /* __FVM_NODAL_ORDER_H__ */
Definition: cs_defs.h:542
uint64_t cs_gnum_t
global mesh entity number
Definition: cs_defs.h:325
Definition: cs_defs.h:543
void fvm_nodal_order_cells(fvm_nodal_t *this_nodal, const cs_gnum_t parent_global_number[])
Definition: fvm_nodal_order.cpp:275
void fvm_nodal_order_faces(fvm_nodal_t *this_nodal, const cs_gnum_t parent_global_number[])
Definition: fvm_nodal_order.cpp:346
void fvm_nodal_order_vertices(fvm_nodal_t *this_nodal, const cs_gnum_t parent_global_number[])
Definition: fvm_nodal_order.cpp:418
