8.3
fvm_interpolate.h
1#ifndef __FVM_INTERPOLATE_H__
2#define __FVM_INTERPOLATE_H__
5 * Interpolate data defined on a nodal representation associated with a mesh.
30#include "cs_defs.h"
33 * Local headers
36#include "fvm_defs.h"
37#include "fvm_nodal.h"
38
43/*=============================================================================
44 * Macro definitions
46
48 * Type definitions
50
51/*=============================================================================
52 * Static global variables
53 *============================================================================*/
54
55/*=============================================================================
56 * Public function prototypes
58
59/*----------------------------------------------------------------------------
60 * Interpolate vertex-based values to points located relative to a mesh.
61 *
62 * Least-squared based interpolation is used for now.
63 *
64 * parameters:
65 * this_nodal <-- pointer to nodal mesh representation structure
66 * entity_dim <-- 3 for location on cells, 2 for faces, 1 for edges,
67 * and 0 for vertices
68 * data_dim <-- data dimension
69 * n_points <-- number of points to locate
70 * location_id <-- id of element (with concatenated sections)
71 * in which each point is located
72 * point_coords <-- point coordinates
73 * src_data <-- source data (interleaved)
74 * dest_data <-> destination data (interleaved)
75 *----------------------------------------------------------------------------*/
76
77void
78fvm_interpolate_vtx_data(const fvm_nodal_t *this_nodal,
79 int entity_dim,
80 int data_dim,
81 cs_lnum_t n_points,
82 const cs_lnum_t location_id[],
83 const cs_coord_t point_coords[],
84 const cs_real_t src_data[],
85 cs_real_t dest_data[]);
86
87/*----------------------------------------------------------------------------*/
88
90
91#endif /* __FVM_INTERPOLATE_H__ */
Definition: cs_defs.h:542
Definition: cs_defs.h:342
double cs_coord_t
Definition: cs_defs.h:340
Definition: cs_defs.h:543
Definition: cs_defs.h:335
void fvm_interpolate_vtx_data(const fvm_nodal_t *this_nodal, int entity_dim, int data_dim, cs_lnum_t n_points, const cs_lnum_t location_id[], const cs_coord_t point_coords[], const cs_real_t src_data[], cs_real_t dest_data[])
Definition: fvm_interpolate.cpp:107
