8.3
fvm_box_priv.h
1#ifndef __FVM_BOX_PRIV_H__
2#define __FVM_BOX_PRIV_H__
5 * Handle bounding boxes.
30#include "cs_defs.h"
33 * Local headers
36#include "fvm_defs.h"
37#include "fvm_morton.h"
38
39#include "fvm_box.h"
45/*============================================================================
46 * Macro and type definitions
48
49/* Structure use to manage box distribution on a tree structure */
50
51#if defined(HAVE_MPI)
52
53struct _fvm_box_distrib_t {
54
55 int n_ranks; /* Number of associated ranks */
56
57 cs_lnum_t n_boxes; /* Number of bounding boxes */
58
59 int max_level; /* Global max level used to compute the
60 distribution */
61 double fit; /* Evaluation of the distribution
62 (lower is better) */
63
64 /* Morton code array defining an index on ranks = resulting distribution */
65
66 fvm_morton_code_t *morton_index; /* size = n_ranks + 1 */
67
68 /* Indexed list on ranks to list related bounding boxes */
69
70 cs_lnum_t *index; /* Index on ranks (size = n_ranks + 1) */
71 cs_lnum_t *list; /* List of bounding boxes associated to each rank */
72};
73
74#endif /* defined(HAVE_MPI) */
75
76/* Set of bounding boxes */
77
79
80 int dim; /* Spatial dimension (1, 2 or 3) */
81 int dimensions[3]; /* Only used in 1 or 2D: X = 0, Y = 1, Z = 2 */
82
83 cs_lnum_t n_boxes; /* Number of bounding boxes */
84 cs_gnum_t n_g_boxes; /* Global number of bounding boxes */
85
86 cs_gnum_t *g_num; /* Array of associated global numbers */
87 cs_coord_t *extents; /* Extents associated with each box:
88 * x_min_0, y_min_0, ..., x_max_0, y_max_0, ...
89 * x_min_n, y_min_n, ..., x_max_n, y_max_n,
90 * (size: n_boxes * dim * 2) */
91
92 cs_coord_t gmin[3]; /* Global minima of the coordinates */
93 cs_coord_t gmax[3]; /* Global maxima of the coordinates */
94
95#if defined(HAVE_MPI)
96 MPI_Comm comm; /* Associated MPI communicator */
97#endif
98
99};
100
101/*----------------------------------------------------------------------------*/
102
104
105#endif /* __FVM_BOX_PRIV_H__ */
Definition: cs_defs.h:542
double cs_coord_t
Definition: cs_defs.h:340
uint64_t cs_gnum_t
global mesh entity number
Definition: cs_defs.h:325
Definition: cs_defs.h:543
Definition: cs_defs.h:335
Definition: fvm_box_priv.h:78
cs_coord_t gmin[3]
Definition: fvm_box_priv.h:92
cs_gnum_t n_g_boxes
Definition: fvm_box_priv.h:84
cs_gnum_t * g_num
Definition: fvm_box_priv.h:86
cs_coord_t gmax[3]
Definition: fvm_box_priv.h:93
cs_lnum_t n_boxes
Definition: fvm_box_priv.h:83
int dimensions[3]
Definition: fvm_box_priv.h:81
int dim
Definition: fvm_box_priv.h:80
cs_coord_t * extents
Definition: fvm_box_priv.h:87
Definition: fvm_morton.h:62
