8.3
fvm_box.h
1#ifndef __FVM_BOX_H__
2#define __FVM_BOX_H__
5 * Handle boxes aligned with Cartesian axes.
30#include "cs_defs.h"
33 * Local headers
36#include "fvm_defs.h"
37#include "fvm_morton.h"
38
43/*============================================================================
44 * Macro and type definitions
46
47/* Collection of boxes */
48
49typedef struct _fvm_box_set_t fvm_box_set_t;
50
51/* Distribution on octree or quadtree */
52
53typedef struct _fvm_box_distrib_t fvm_box_distrib_t;
54
55/*============================================================================
56 * Public function definitions
58
59/*----------------------------------------------------------------------------
60 * Create a set of boxes and initialize it.
61 *
62 * parameters:
63 * dim <-- spatial dimension
64 * normalize <-- 1 if boxes are to be normalized, 0 otherwize
65 * allow_projection <-- if 1, project to lower dimension if all boxes
66 * are cut by the median plane of the set.
67 * n_boxes <-- number of elements to create
68 * box_gnum <-- global numbering of boxes
69 * extents <-- coordinate extents (size: n_boxes*dim*2, as
70 * xmin1, ymin1, .. xmax1, ymax1, ..., xmin2, ...)
71 * comm <-- associated MPI communicator
72 *
73 * returns:
74 * a new allocated pointer to a fvm_box_set_t structure.
75 *---------------------------------------------------------------------------*/
76
77#if defined(HAVE_MPI)
78fvm_box_set_t *
79fvm_box_set_create(int dim,
80 int normalize,
81 int allow_projection,
82 cs_lnum_t n_boxes,
83 const cs_gnum_t *box_gnum,
84 const cs_coord_t *box_extents,
85 MPI_Comm comm);
86#else
87fvm_box_set_t *
88fvm_box_set_create(int dim,
89 int normalize,
90 int allow_projection,
91 cs_lnum_t n_boxes,
92 const cs_gnum_t *box_gnum,
93 const cs_coord_t *box_extents);
94
95#endif
96
97/*----------------------------------------------------------------------------
98 * Destroy a fvm_box_set_t structure.
99 *
100 * parameters:
101 * boxes <-> pointer to pointer to the fvm_box_set_t structure to delete
102 *----------------------------------------------------------------------------*/
103
104void
105fvm_box_set_destroy(fvm_box_set_t **boxes);
106
107/*----------------------------------------------------------------------------
108 * Return the dimension associated with a set of boxes.
109 *
110 * parameters:
111 * boxes <-- pointer to set of boxes
112 *
113 * returns:
114 * associated spatial dimension
115 *---------------------------------------------------------------------------*/
116
117int
118fvm_box_set_get_dim(const fvm_box_set_t *boxes);
119
120/*----------------------------------------------------------------------------
121 * Return the local number of boxes in a set.
122 *
123 * parameters:
124 * boxes <-- pointer to set of boxes
125 *
126 * returns:
127 * local number of boxes
128 *---------------------------------------------------------------------------*/
129
131fvm_box_set_get_size(const fvm_box_set_t *boxes);
132
133/*----------------------------------------------------------------------------
134 * Return the global number of boxes in a set.
135 *
136 * parameters:
137 * boxes <-- pointer to set of boxes
138 *
139 * returns:
140 * local number of boxes
141 *---------------------------------------------------------------------------*/
142
144fvm_box_set_get_global_size(const fvm_box_set_t *boxes);
145
146/*----------------------------------------------------------------------------
147 * Return extents associated with a set of boxes.
148 *
149 * The extents array is organized in the following fashion:
150 * {x_min_0, y_min_0, ..., x_max_0, y_max_0, ...
151 * x_min_n, y_min_n, ..., x_max_n, y_max_n, ...}
152 *
153 * Its size is thus: n_boxes * dim * 2.
154 *
155 * parameters:
156 * boxes <-- pointer to set of boxes
157 *
158 * returns:
159 * pointer to extents array
160 *---------------------------------------------------------------------------*/
161
162const cs_coord_t *
163fvm_box_set_get_extents(fvm_box_set_t *boxes);
164
165/*----------------------------------------------------------------------------
166 * Return global numbers associated with a set of boxes.
167 *
168 * parameters:
169 * boxes <-- pointer to set of boxes
170 *
171 * returns:
172 * pointer to global box numbers array
173 *---------------------------------------------------------------------------*/
174
175const cs_gnum_t *
176fvm_box_set_get_g_num(fvm_box_set_t *boxes);
177
178/*----------------------------------------------------------------------------
179 * Build a Morton_index to get a well-balanced distribution of the boxes.
180 *
181 * parameters:
182 * boxes <-- pointer to associated fvm_box_set_t structure
183 * distrib <-> pointer to a fvm_box_distrib_t structure
184 * n_leaves <-- number of leaves with weight > 0
185 * leaf_codes <-- Morton code for each leaf
186 * weight <-- number of boxes related to each leaf
187 *---------------------------------------------------------------------------*/
188
189void
190fvm_box_set_build_morton_index(const fvm_box_set_t *boxes,
191 fvm_box_distrib_t *distrib,
192 cs_lnum_t n_leaves,
193 fvm_morton_code_t *leaf_codes,
194 cs_lnum_t *weight);
195
196/*----------------------------------------------------------------------------
197 * Redistribute boxes over the ranks according to the Morton index to
198 * assume a better balanced distribution of the boxes.
199 *
200 * parameters:
201 * box_distrib <-- data structure on box distribution
202 * box_set <-> pointer to the structure to redistribute
203 *---------------------------------------------------------------------------*/
204
205void
207 fvm_box_set_t *boxes);
208
209/*----------------------------------------------------------------------------
210 * Dump a fvm_box_set_t structure.
211 *
212 * parameters:
213 * box_set <-- pointer to the fvm_box_t structure
214 * verbosity <-- verbosity level (0 or 1)
215 *----------------------------------------------------------------------------*/
216
217void
218fvm_box_set_dump(const fvm_box_set_t *boxes,
219 int verbosity);
220
221#if defined(HAVE_MPI)
222
223/*----------------------------------------------------------------------------
224 * Create a fvm_box_distrib_t structure.
225 *
226 * parameters:
227 * n_boxes <-- number of boxes
228 * n_g_boxes <-- global number of boxes
229 * max_level <-- max level reached locally in the related tree
230 * comm <-- MPI comm. on which distribution takes place
231 *
232 * returns:
233 * a pointer to a new allocated fvm_box_distrib_t structure.
234 *---------------------------------------------------------------------------*/
235
237fvm_box_distrib_create(cs_lnum_t n_boxes,
238 cs_gnum_t n_g_boxes,
239 int max_level,
240 MPI_Comm comm);
241
242/*----------------------------------------------------------------------------
243 * Destroy a fvm_box_distrib_t structure.
244 *
245 * parameters:
246 * distrib <-> pointer to pointer to the structure to destroy
247 *---------------------------------------------------------------------------*/
248
249void
250fvm_box_distrib_destroy(fvm_box_distrib_t **distrib);
251
252/*----------------------------------------------------------------------------
253 * Delete redundancies in box distribution
254 *
255 * parameters:
256 * distrib <-> pointer to the fvm_box_distrib_t structure
257 *---------------------------------------------------------------------------*/
258
259void
260fvm_box_distrib_clean(fvm_box_distrib_t *distrib);
261
262/*----------------------------------------------------------------------------
263 * Display a histogramm on leaves associated to the boxes and
264 * several other pieces of information (min, max, ...)
265 *
266 * parameters:
267 * distrib <-- pointer to the fvm_box_distrib_t structure
268 * comm <-- associated MPI communicator
269 *---------------------------------------------------------------------------*/
270
271void
272fvm_box_distrib_dump_statistics(const fvm_box_distrib_t *distrib,
273 MPI_Comm comm);
274
275#endif /* defined(HAVE_MPI) */
276
277/*----------------------------------------------------------------------------*/
278
280
281#endif /* __FVM_BOX_H__ */
Definition: cs_defs.h:542
double cs_coord_t
Definition: cs_defs.h:340
uint64_t cs_gnum_t
global mesh entity number
Definition: cs_defs.h:325
Definition: cs_defs.h:543
Definition: cs_defs.h:335
void fvm_box_set_dump(const fvm_box_set_t *boxes, int verbosity)
Definition: fvm_box.cpp:645
const cs_coord_t * fvm_box_set_get_extents(fvm_box_set_t *boxes)
Definition: fvm_box.cpp:479
void fvm_box_set_redistribute(const fvm_box_distrib_t *box_distrib, fvm_box_set_t *boxes)
Definition: fvm_box.cpp:565
void fvm_box_set_build_morton_index(const fvm_box_set_t *boxes, fvm_box_distrib_t *distrib, cs_lnum_t n_leaves, fvm_morton_code_t *leaf_codes, cs_lnum_t *weight)
Definition: fvm_box.cpp:516
cs_gnum_t fvm_box_set_get_global_size(const fvm_box_set_t *boxes)
Definition: fvm_box.cpp:452
int fvm_box_set_get_dim(const fvm_box_set_t *boxes)
Definition: fvm_box.cpp:410
cs_lnum_t fvm_box_set_get_size(const fvm_box_set_t *boxes)
Definition: fvm_box.cpp:431
fvm_box_set_t * fvm_box_set_create(int dim, int normalize, int allow_projection, cs_lnum_t n_boxes, const cs_gnum_t *box_gnum, const cs_coord_t *box_extents)
Definition: fvm_box.cpp:220
Definition: fvm_box.h:53
const cs_gnum_t * fvm_box_set_get_g_num(fvm_box_set_t *boxes)
Definition: fvm_box.cpp:497
void fvm_box_set_destroy(fvm_box_set_t **boxes)
Definition: fvm_box.cpp:384
Definition: fvm_box_priv.h:78
Definition: fvm_morton.h:62
