8.3
cs_mesh_smoother.h
1#ifndef __CS_MESH_SMOOTHER_H__
2#define __CS_MESH_SMOOTHER_H__
5 * Mesh smoothing.
31 * Local headers
34#include "cs_base.h"
35#include "cs_mesh.h"
36#include "cs_mesh_quantities.h"
43 * Macro definitions
45
47 * Type definitions
49
50/*=============================================================================
51 * Public function prototypes
53
54/*----------------------------------------------------------------------------
55 * Set fixed vertices flag based on feature angle criterion.
56 *
57 * parameters:
58 * mesh <-- pointer to a cs_mesh_t structure
59 * feature_angle <-- feature angle (bounded between 0 and 90 degrees)
60 * vtx_is_fixed --> array to define vertices mobility (1: fixed, 0: free)
61 *----------------------------------------------------------------------------*/
62
63void
65 cs_real_t feature_angle,
66 int vtx_is_fixed[]);
67
68/*----------------------------------------------------------------------------
69 * Unwarping smoother.
70 *
71 * parameters:
72 * mesh <-- pointer to a cs_mesh_t structure
73 * vtx_is_fixed --> array to define vertices mobility (1 : fixed, 0 : free)
74 *----------------------------------------------------------------------------*/
75
76void
78 const int vtx_is_fixed[]);
79
80/*----------------------------------------------------------------------------*/
81
83
84#endif /* __CS_MESH_SMOOTHER_H__ */
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
void cs_mesh_smoother_fix_by_feature(cs_mesh_t *mesh, cs_real_t feature_angle, int vtx_is_fixed[])
Definition: cs_mesh_smoother.cpp:792
void cs_mesh_smoother_unwarp(cs_mesh_t *mesh, const int vtx_is_fixed[])
Unwarping smoother.
Definition: cs_mesh_smoother.cpp:881
Definition: mesh.f90:26
Definition: cs_mesh.h:85
