8.3
cs_lagr_dlvo.h
1#ifndef __CS_LAGR_DLVO_H__
2#define __CS_LAGR_DLVO_H__
5 * Functions and types for the clogging modeling
31 * Local headers
34#include "cs_defs.h"
36#include "cs_lagr_particle.h"
43 * Type definitions
45
46typedef struct {
58
60
61/*=============================================================================
62 * Function definitions
63 *============================================================================*/
64
65/*----------------------------------------------------------------------------
66 * DLVO initialization
67 *----------------------------------------------------------------------------*/
68
69void
70cs_lagr_dlvo_init(const cs_real_t water_permit,
71 const cs_real_t ionic_strength,
72 const cs_real_t temperature[],
73 const cs_real_t valen,
74 const cs_real_t phi_p,
75 const cs_real_t phi_s,
76 const cs_real_t cstham,
77 const cs_real_t csthpp,
78 const cs_real_t lambda_vdw);
79
80/*----------------------------------------------------------------------------
81 * Deallocate the arrays storing temperature and Debye length.
82 *----------------------------------------------------------------------------*/
83
84void
86
87/*----------------------------------------------------------------------------
88 * Compute the energy barrier for a smooth wall.
89 *----------------------------------------------------------------------------*/
90
91void
92cs_lagr_barrier(const void *particle,
93 const cs_lagr_attribute_map_t *attr_map,
94 cs_lnum_t iel,
95 cs_real_t *energy_barrier);
96
97/*----------------------------------------------------------------------------
98 * Compute the energy barrier for two spheres.
99 *----------------------------------------------------------------------------*/
100
101void
103 cs_lnum_t iel,
104 cs_real_t *energy_barrier);
105
106/*----------------------------------------------------------------------------
107 * Van der Waals interaction between a sphere and a plane
108 * using formulas from Czarnecki (large distances)
109 * and Gregory (small distances)
110 *----------------------------------------------------------------------------*/
111
114 cs_real_t rpart,
115 cs_real_t lambda_vdw,
116 cs_real_t cstham);
117
118/*----------------------------------------------------------------------------
119 * Calculation of the Van der Waals interaction between two spheres
120 * following the formula from Gregory (1981a)
121 *----------------------------------------------------------------------------*/
122
125 cs_real_t rpart1,
126 cs_real_t rpart2,
127 cs_real_t lambda_vdw,
128 cs_real_t cstham);
129
130/*----------------------------------------------------------------------------
131 * Electric Double Layer (EDL) interaction between a sphere and a plane
132 * using the formula from Bell & al (1970)
133 * based on the McCartney & Levine method
134 *----------------------------------------------------------------------------*/
135
138 cs_real_t rpart,
139 cs_real_t valen,
140 cs_real_t phi1,
141 cs_real_t phi2,
142 cs_real_t temp,
143 cs_real_t debye_length,
144 cs_real_t water_permit);
145
146/*----------------------------------------------------------------------------
147 * Calculation of the EDL interaction between two spheres
148 * using the formula from Bell & al (1970)
149 * based on the McCartney & Levine method
150 *----------------------------------------------------------------------------*/
151
154 cs_real_t rpart1,
155 cs_real_t rpart2,
156 cs_real_t valen,
157 cs_real_t phi1,
158 cs_real_t phi2,
159 cs_real_t temp,
160 cs_real_t debye_length,
161 cs_real_t water_permit);
162
163/*----------------------------------------------------------------------------*/
164
166
167#endif /* __CS_LAGR_DLVO_H__ */
168
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
Definition: cs_defs.h:335
cs_real_t cs_lagr_van_der_waals_sphere_sphere(cs_real_t distcc, cs_real_t rpart1, cs_real_t rpart2, cs_real_t lambda_vdw, cs_real_t cstham)
Definition: cs_lagr_dlvo.cpp:344
void cs_lagr_dlvo_finalize(void)
Definition: cs_lagr_dlvo.cpp:190
cs_real_t cs_lagr_van_der_waals_sphere_plane(cs_real_t distp, cs_real_t rpart, cs_real_t lambda_vdw, cs_real_t cstham)
Definition: cs_lagr_dlvo.cpp:311
cs_real_t cs_lagr_edl_sphere_sphere(cs_real_t distcc, cs_real_t rpart1, cs_real_t rpart2, cs_real_t valen, cs_real_t phi1, cs_real_t phi2, cs_real_t temp, cs_real_t debye_length, cs_real_t water_permit)
Definition: cs_lagr_dlvo.cpp:411
cs_real_t cs_lagr_edl_sphere_plane(cs_real_t distp, cs_real_t rpart, cs_real_t valen, cs_real_t phi1, cs_real_t phi2, cs_real_t temp, cs_real_t debye_length, cs_real_t water_permit)
Definition: cs_lagr_dlvo.cpp:364
void cs_lagr_barrier_pp(cs_real_t dpart, cs_lnum_t iel, cs_real_t *energy_barrier)
Definition: cs_lagr_dlvo.cpp:257
void cs_lagr_dlvo_init(const cs_real_t water_permit, const cs_real_t ionic_strength, const cs_real_t temperature[], const cs_real_t valen, const cs_real_t phi_p, const cs_real_t phi_s, const cs_real_t cstham, const cs_real_t csthpp, const cs_real_t lambda_vdw)
Definition: cs_lagr_dlvo.cpp:119
void cs_lagr_barrier(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lnum_t iel, cs_real_t *energy_barrier)
Definition: cs_lagr_dlvo.cpp:201
Definition: cs_lagr_particle.h:189
Definition: cs_lagr_dlvo.h:46
Definition: cs_lagr_dlvo.h:49
cs_real_t cstham
Definition: cs_lagr_dlvo.h:55
cs_real_t * temperature
Definition: cs_lagr_dlvo.h:52
cs_real_t * debye_length
Definition: cs_lagr_dlvo.h:54
cs_real_t phi_s
Definition: cs_lagr_dlvo.h:51
Definition: cs_lagr_dlvo.h:57
Definition: cs_lagr_dlvo.h:48
cs_real_t csthpp
Definition: cs_lagr_dlvo.h:56
cs_real_t phi_p
Definition: cs_lagr_dlvo.h:50
cs_real_t valen
Definition: cs_lagr_dlvo.h:53
