8.3
cs_lagr_clogging.h
1#ifndef __CS_LAGR_CLOGGING_H__
2#define __CS_LAGR_CLOGGING_H__
5 * Clogging modeling.
31 * Local headers
34#include "cs_defs.h"
35#include "cs_lagr_particle.h"
36
37/*----------------------------------------------------------------------------*/
38
41/*============================================================================
42 * Type definitions
43 *============================================================================*/
45typedef struct {
46
55
61
63
64/*============================================================================
65 * Public function definitions
66 *============================================================================*/
67
68/*----------------------------------------------------------------------------
69 * Clogging initialization.
70 *
71 * - Retrieve various parameters for storing in global structure.
72 * - Compute and store the Debye screening length
73 *----------------------------------------------------------------------------*/
74
75void
76cloginit(const cs_real_t *water_permit,
77 const cs_real_t *ionic_strength,
78 const cs_real_t *jamming_limit,
79 const cs_real_t *min_porosity,
80 const cs_real_t *diam_mean,
81 const cs_real_t temperature[],
82 const cs_real_t *valen,
83 const cs_real_t *phi_p,
84 const cs_real_t *phi_s,
85 const cs_real_t *cstham,
86 const cs_real_t *csthpp,
87 const cs_real_t *lambda_vdw
88 );
89
90/*----------------------------------------------------------------------------
91 * Clogging finalization.
92 *
93 * Deallocate the arrays storing temperature and Debye length.
94 *----------------------------------------------------------------------------*/
95
96void
98
99/*----------------------------------------------------------------------------
100 * Clogging:
101 *
102 * - Compute the number of deposited particles in contact with the depositing
103 * particle
104 * - Re-compute the energy barrier if this number is greater than zero
105 *
106 * parameters:
107 * particle <-- pointer to particle data
108 * attr_map <-- pointer to attribute map
109 * iel <-- id of cell where the particle is
110 * face_area <-- area of face
111 * energy_barrier <-> energy barrier
112 * surface_coverage <-> surface coverage
113 * limit <-> jamming limit
114 * mporos <-> minimum porosity
115 *
116 * returns:
117 * number of deposited particles in contact with the depositing particle
118 *----------------------------------------------------------------------------*/
119
120int
121cs_lagr_clogging_barrier(const void *particle,
122 const cs_lagr_attribute_map_t *attr_map,
123 cs_lnum_t iel,
124 cs_real_t *energy_barrier,
125 cs_real_t *surface_coverage,
126 cs_real_t *limit,
127 cs_real_t *mporos);
128
129/*----------------------------------------------------------------------------*/
130
132
133#endif /* __CS_LAGR_CLOGGING_H__ */
134
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
Definition: cs_defs.h:335
void cloginit(const cs_real_t *water_permit, const cs_real_t *ionic_strength, const cs_real_t *jamming_limit, const cs_real_t *min_porosity, const cs_real_t *diam_mean, const cs_real_t temperature[], const cs_real_t *valen, const cs_real_t *phi_p, const cs_real_t *phi_s, const cs_real_t *cstham, const cs_real_t *csthpp, const cs_real_t *lambda_vdw)
Definition: cs_lagr_clogging.cpp:113
void cs_lagr_clogging_finalize(void)
Definition: cs_lagr_clogging.cpp:194
int cs_lagr_clogging_barrier(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lnum_t iel, cs_real_t *energy_barrier, cs_real_t *surface_coverage, cs_real_t *limit, cs_real_t *mporos)
Definition: cs_lagr_clogging.cpp:221
Definition: cs_lagr_particle.h:189
Definition: cs_lagr_clogging.h:45
cs_real_t ionic_strength
Definition: cs_lagr_clogging.h:48
cs_real_t diam_mean
Definition: cs_lagr_clogging.h:51
cs_real_t cstham
Definition: cs_lagr_clogging.h:58
cs_real_t * temperature
Definition: cs_lagr_clogging.h:56
cs_real_t min_porosity
Definition: cs_lagr_clogging.h:50
cs_real_t * debye_length
Definition: cs_lagr_clogging.h:57
cs_real_t phi_s
Definition: cs_lagr_clogging.h:54
cs_real_t jamming_limit
Definition: cs_lagr_clogging.h:49
cs_real_t lambda_vdw
Definition: cs_lagr_clogging.h:60
cs_real_t water_permit
Definition: cs_lagr_clogging.h:47
cs_real_t csthpp
Definition: cs_lagr_clogging.h:59
cs_real_t phi_p
Definition: cs_lagr_clogging.h:53
cs_real_t valen
Definition: cs_lagr_clogging.h:52
