46#define CS_CDO_BC_DEFAULT_DEF -1
61#define CS_CDO_BC_NEUMANN (1 << 0)
65#define CS_CDO_BC_FULL_NEUMANN (1 << 1)
70#define CS_CDO_BC_SYMMETRY (1 << 2)
74#define CS_CDO_BC_DIRICHLET (1 << 3)
78#define CS_CDO_BC_HMG_DIRICHLET (1 << 4)
82#define CS_CDO_BC_ROBIN (1 << 5)
86#define CS_CDO_BC_TANGENTIAL_DIRICHLET (1 << 6)
90#define CS_CDO_BC_WALL_PRESCRIBED (1 << 7)
180 " %s: Empty desciption buffer.", __func__);
185 sprintf(desc,
"%s",
"Homogenous Dirichlet");
188 sprintf(desc,
"%s",
"Dirichlet");
191 sprintf(desc,
"%s",
"Homogeneous Neumann or Sliding for vectors");
194 sprintf(desc,
"%s",
"Neumann");
197 sprintf(desc,
"%s",
"Full Neumann");
200 sprintf(desc,
"%s",
"Robin");
203 sprintf(desc,
"%s",
"Dirichlet on the tangential component");
208 "%s: Invalid case. Please contact the support.\n", __func__);
248 _(
"invalid boundary condition CS_BC_GENERALIZED_SYM for CDO"));
Definition: bft_error.cpp:193
static void cs_cdo_bc_get_desc(cs_flag_t bc_flag, char *desc)
Convert a flag into a description.
Definition: cs_cdo_bc.h:175
cs_cdo_bc_face_t * cs_cdo_bc_free(cs_cdo_bc_face_t *face_bc)
Free a cs_cdo_bc_face_t structure.
Definition: cs_cdo_bc.cpp:352
static bool cs_cdo_bc_is_circulation(cs_flag_t flag)
Check if a flag is associated to a Dirichlet BC (homogeneous or not)
Definition: cs_cdo_bc.h:343
static cs_flag_t cs_cdo_bc_get_flag(cs_param_bc_type_t bc_type)
Convert a cs_param_bc_type_t into a flag (enable multiple type for a same entity as required for vert...
Definition: cs_cdo_bc.h:225
static bool cs_cdo_bc_is_neumann(cs_flag_t flag)
Check if a flag is associated to a Neumann BC (homogeneous or not)
Definition: cs_cdo_bc.h:302
static bool cs_cdo_bc_is_dirichlet(cs_flag_t flag)
Definition: cs_cdo_bc.h:281
static bool cs_cdo_bc_is_sliding(cs_flag_t flag)
Check if a flag is associated to a sliding boundary.
Definition: cs_cdo_bc.h:323
cs_cdo_bc_face_t * cs_cdo_bc_face_define(cs_param_bc_type_t default_bc, bool is_steady, int dim, int n_defs, cs_xdef_t **defs, cs_lnum_t n_b_faces)
Define the structure which translates the BC definitions from the user viewpoint into a ready-to-use ...
Definition: cs_cdo_bc.cpp:150
Definition: cs_defs.h:542
#define _(String)
Definition: cs_defs.h:67
Definition: cs_defs.h:543
Definition: cs_defs.h:335
unsigned short int cs_flag_t
Definition: cs_defs.h:344
cs_param_bc_type_t
Definition: cs_param_types.h:481
@ CS_BC_GENERALIZED_SYM
Definition: cs_param_types.h:494
@ CS_BC_NEUMANN_FULL
Definition: cs_param_types.h:490
@ CS_BC_CIRCULATION
Definition: cs_param_types.h:492
@ CS_BC_NEUMANN
Definition: cs_param_types.h:486
@ CS_BC_SYMMETRY
Definition: cs_param_types.h:487
@ CS_BC_DIRICHLET
Definition: cs_param_types.h:484
@ CS_BC_HMG_DIRICHLET
Definition: cs_param_types.h:483
@ CS_BC_WALL_MODELLED
Definition: cs_param_types.h:488
@ CS_BC_ROBIN
Definition: cs_param_types.h:491
Definition: cs_cdo_bc.h:90
Definition: cs_cdo_bc.h:78
Definition: cs_cdo_bc.h:70
Definition: cs_cdo_bc.h:82
Definition: cs_cdo_bc.h:65
Definition: cs_cdo_bc.h:86
Definition: cs_cdo_bc.h:61
Definition: cs_cdo_bc.h:74
Definition: cs_cdo_bc.h:106
cs_lnum_t * hmg_dir_ids
Definition: cs_cdo_bc.h:129
cs_lnum_t n_robin_faces
Definition: cs_cdo_bc.h:142
cs_lnum_t n_sliding_faces
Definition: cs_cdo_bc.h:147
cs_flag_t * flag
Definition: cs_cdo_bc.h:114
cs_lnum_t n_nhmg_neu_faces
Definition: cs_cdo_bc.h:137
cs_lnum_t n_b_faces
Definition: cs_cdo_bc.h:110
cs_lnum_t * nhmg_neu_ids
Definition: cs_cdo_bc.h:138
cs_lnum_t n_hmg_neu_faces
Definition: cs_cdo_bc.h:135
cs_lnum_t * sliding_ids
Definition: cs_cdo_bc.h:148
cs_lnum_t n_circulation_faces
Definition: cs_cdo_bc.h:152
cs_lnum_t n_nhmg_dir_faces
Definition: cs_cdo_bc.h:130
cs_lnum_t * robin_ids
Definition: cs_cdo_bc.h:143
bool is_steady
Definition: cs_cdo_bc.h:108
cs_lnum_t * nhmg_dir_ids
Definition: cs_cdo_bc.h:131
cs_lnum_t * circulation_ids
Definition: cs_cdo_bc.h:153
cs_lnum_t * hmg_neu_ids
Definition: cs_cdo_bc.h:136
short int * def_ids
Definition: cs_cdo_bc.h:119
cs_lnum_t n_hmg_dir_faces
Definition: cs_cdo_bc.h:128
Definition: cs_xdef.h:160
