8.2
fvm_nodal_project.h
1 #ifndef __FVM_NODAL_PROJECT_H__
2 #define __FVM_NODAL_PROJECT_H__
5  * Projection of nodal sections associated with a mesh
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
42 /*=============================================================================
43  * Public function prototypes
45
46 /*----------------------------------------------------------------------------
47  * Project an extruded mesh to its base plane.
48  *
49  * This is currently only possible for 2D element topologies.
50  *
51  * parameters:
52  * this_nodal <-> pointer to structure that should be cut in edges
53  * chosen_axis <-- indicate which axis is selected to extract edges
54  * error_count --> number of triangulation errors counter (optional)
55  *----------------------------------------------------------------------------*/
56
57 void
58 fvm_nodal_project(fvm_nodal_t *this_nodal,
59  int chosen_axis,
60  cs_lnum_t *error_count);
61
62 /*----------------------------------------------------------------------------
63  * Reduce the spatial dimension of a mesh, discarding the last coordinate
64  * component.
65  *
66  * The mesh's spatial dimension is reduced by 1.
67  *
68  * parameters:
69  * this_nodal <-> pointer to structure that projected
70  * matrix <-- projection matrix
71  * 3D -> 2D: (a11, a12, a13, a21, a22, a23)
72  * 2D -> 1D: (a11, a12)
73  *----------------------------------------------------------------------------*/
74
75 void
76 fvm_nodal_project_coords(fvm_nodal_t *this_nodal,
77  double matrix[]);
78
79 /*----------------------------------------------------------------------------*/
80
82
83 #endif /* __FVM_NODAL_PROJECT_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:529
Definition: cs_defs.h:325
void fvm_nodal_project(fvm_nodal_t *this_nodal, int chosen_axis, cs_lnum_t *error_count)
Definition: fvm_nodal_project.c:412
void fvm_nodal_project_coords(fvm_nodal_t *this_nodal, double matrix[])
Definition: fvm_nodal_project.c:505
