Additional right-hand side source terms for velocity components equation (Navier-Stokes)
Local variables and initialization
Definition: cs_defs.h:332
Definition: cs_defs.h:325
Definition: cs_field.c:2465
@ rho
#define CS_F_(e)
double precision, dimension(:), pointer cell_f_vol
fluid volume of each cell
Definition: mesh.f90:112
Definition: cs_field.h:131
Example
Example of arbitrary source term for component
appearing in the equation under the form:
In the following example:
with:
CKP = 1.0 (in
) (return term on velocity)
MMT = 100.0 (in
) (momentum production by volume and time unit)
which yields:
st_imp[i][0][0] = volume[i] * A = - volume[i]*(rho*CKP)
st_exp[i][0] = volume[i] * B = volume[i]*(XMMT)
Body
_st_imp[i][0][0] = -
cell_f_vol[i] * cpro_rom[i] * ckp;
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:356
@ vel
Example of a boussinesq momentum source term
Example to add Boussinesq source to the z component of
Body
@ t
Definition: cs_physical_constants.c:445
real(c_double), pointer, save t0
reference temperature.
Definition: cstphy.f90:217
real(c_double), pointer, save ro0
reference density.
Definition: cstphy.f90:153
double ro0
Definition: cs_physical_constants.h:74
double t0
Definition: cs_physical_constants.h:82
