8.2
Examples of ALE boundary conditions
Mapping relative to ALE
const cs_lnum_t n_b_faces = domain->mesh->n_b_faces;
const cs_lnum_t *b_face_vtx_idx = domain->mesh->b_face_vtx_idx;
const cs_lnum_t *b_face_vtx_lst = domain->mesh->b_face_vtx_lst;
const cs_lnum_t *b_face_cells = domain->mesh->b_face_cells;
const int nt_cur = domain->time_step->nt_cur;
const cs_real_t *dt = CS_F_(dt)->val;
/* nodes displacement */
cs_real_3_t *disale
= (cs_real_3_t*)cs_field_by_name("mesh_displacement")->val;
const cs_zone_t *zn = NULL;
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
Definition: cs_defs.h:325
Definition: cs_field.c:2489
@ dt
#define CS_F_(e)
cs_real_t * val
Definition: cs_field.h:152
Definition: cs_zone.h:55
Assign boundary conditions to boundary faces
One may use selection criteria to filter boundary case subsets.
Loop on faces from a subset.
Set the boundary condition for each face.
Calculation of displacement at current time step
Example 1
Example : For boundary faces of color 4 assign a fixed velocity
/* Example: For boundary faces of zone 'fv' assign a fixed velocity */
/* Calculation of displacement at current time step */
const cs_real_t deltaa = sin(3.141596*(nt_cur-1)/50);
const cs_real_t delta = sin(3.141596*nt_cur/50.);
for (cs_lnum_t ilelt = 0; ilelt < zn->n_elts; ilelt++) {
const cs_lnum_t face_id = zn->elt_ids[ilelt];
const cs_lnum_t c_id = b_face_cells[face_id];
ale_bc_type[face_id] = CS_BOUNDARY_ALE_IMPOSED_VEL;
mesh_u->bc_coeffs->rcodcl1[n_b_faces*0 + face_id] = 0;
mesh_u->bc_coeffs->rcodcl1[n_b_faces*1 + face_id] = 0;
mesh_u->bc_coeffs->rcodcl1[n_b_faces*2 + face_id] = (delta-deltaa)/dt[c_id];
@ CS_BOUNDARY_ALE_IMPOSED_VEL
Definition: cs_boundary.h:142
@ mesh_u
Definition: cs_field_pointer.h:86
Definition: cs_field.h:131
const cs_lnum_t * elt_ids
Definition: cs_zone.h:65
cs_lnum_t n_elts
Definition: cs_zone.h:64
Example 2
Example: For boundary face of color 5 assign a fixed displacement on nodes
for (cs_lnum_t ii = b_face_vtx_idx[face_id];
ii < b_face_vtx_idx[face_id+1];
ii++) {
const cs_lnum_t vtx_id = b_face_vtx_lst[ii];
if (impale[vtx_id] == 0) {
disale[vtx_id][0] = 0;
disale[vtx_id][1] = 0;
disale[vtx_id][2] = delta;
impale[vtx_id] = 1;
Example 3
Example : For boundary faces of color 6 assign a sliding boundary
ale_bc_type[face_id] = CS_BOUNDARY_ALE_SLIDING;
@ CS_BOUNDARY_ALE_SLIDING
Definition: cs_boundary.h:141
Example 4
Example : Prescribe elsewhere a fixed boundary
zn = cs_boundary_zone_by_name("fixed");
ale_bc_type[face_id] = CS_BOUNDARY_ALE_FIXED;
@ CS_BOUNDARY_ALE_FIXED
Definition: cs_boundary.h:140
