8.2
How to submit cases on cluster with SLURM
SLURM command lines
This page explains how to submit cases on a cluster using the SLURM resource manager with the studymanager tool.
In order to activate the submission of cases on cluster with SLURM, it is necessary to specify at least one of the two following options:
  • --slurm-batch-size=N: maximum number of cases per batch in SLURM batch mode (50 by default).
  • --slurm-batch-wtime=M: maximum computation time in hours per batch in SLURM batch mode (12 hours by default).
For instance, the following command
$ code_saturne smgr -f smgr.xml -r --with-tags=coarse --slurm-batch-size=20 --slurm-batch-wtime=8
will submit batch of cases with a maximum of 20 cases per batch and a maximum total computation time of 8 hours. The number of cases per batch could then be inferior to 20 if the total computation time exceeds 8h.
In order to compute the total computation time per batch, it is necessary to specify an expected computation time per case (HH:MM) in the smgr xml file (3 hours by default).
<study label="MyStudy1" status="on">
<case label="Grid1" run_id="Grid1" status="on" compute="on" post="on" expected_time="2:15"/>
<case label="Grid2" run_id="Grid2" status="on" compute="on" post="on" expected_time="5:00"/>
</study>
In this case, the run Grid1 has an expected computation time of 2 hours and 15 minutes and the one of Grid2 is 5 hours.
SLURM batch options
SLURM batch files are automatically generated in the folder slurm_files in destination. The following file is an example of a SLURM file used with the SLURM batch mode.
#!/bin/sh
#SBATCH --ntasks=1
#SBATCH --time=0:12:00
#SBATCH --output=vnv_6
#SBATCH --error=vnv_6
#SBATCH --job-name=saturne_vnv_6
  • ntasks : number of processes required for the computation.
    • All cases are automatically sorted by number of required processes so that the number of tasks per batch is the same.
  • time : sum of the computation times of the cases in the batch
Batch cases which require 6 or more processes will be executed in exclusive mode (i.e. no other submission will run on the node).
Additional SLURM batch parameters can be also specified at run time using the --slurm-batch-arg option. This option only takes into account one argument at a time. For example, to add the "exclusive" and send an e-mail notification use the following command-line option: --slurm-batch-arg=--exclusive --slurm-batch-arg=--mail-user=name.last@email.com
Warning
For EDF users, the wckey argument should be defined. It can be done by either using --slurm-batch-arg=--wckey=<key> during run time, or by setting an environment variable with the following command: export SBATCH_WCKEY=<key>.
All ouput and error files are also in the folder slurm_files in destination.
Dependency between cases
Job-dependencies are defined automatically such that blocks of dependency level M will wait until all blocks of level M-1 are successfully finished.
Three methods are available to define a dependency between cases:
  • Set a restart in the data settings of a case using the graphical user interface of code_saturne;
  • Add a restart in parametric options of a SMGR parameter file using -r or --restart argument
    <study label='STUDY' status='on'>
    <case label='CASE1' status='on' compute="on" post="on">
    <parametric args="-r run_id"/>
    </case>
    </study>
  • Add a <depends> node to a case in SMGR parameter file :
    <depends args="STUDY/CASE/RESU/run_id"/>
    </case>
    </study>
Dependencies defined using a <depends> node have priority over those deduced from parametric arguments. They both have priority over restarts in code_saturne data settings.
In the rare cases where dependencies are not related to restarts, the <depends> approach allow fine-grained control. In other cases, dependencies are deduced from restart definitions, so no additional user settings are needed.
Postprocessing and analysis
The state analysis is automatically added with the slurm batch mode. This final batch will depend on all previous submissions. It can also include postprocessing and comparison steps if these options are activated.
Example
In the following example, a list of 8 cases is launched in SLURM batch mode:
$ code_saturne smgr -f smgr.xml -rp --slurm-batch-size=2 --slurm-batch-wtime=5
Exemple of cases allocation per batch
Here are some explanations on cases allocation per batch :
  • In level 0, batch 1 is limited by the number of cases with the same number of processes. Batch 2 is limited to one case (CASE1/run3) as the maximum time in this batch would have exceeded 5 hours including the next case (CASE2/run1). Batch 3 only includes the last case at level 0.
  • In level 1, batch 4 is limited by the maximum number of cases per batch (2). Batch 5 only includes the last case at level 1. Batches 4 and 5 depends on all batches from level 0.
  • In level 2, batch 6 only includes the last case of the level. It depends on all batches from level 0 and 1.
  • In level 3, batch 7 includes postprocessing and state analysis. The final batch depends on all cases from all steps.
