1 #ifndef __CS_WALLCONDENSATION_1DTHERMAL_H__
2 #define __CS_WALLCONDENSATION_1DTHERMAL_H__
Definition: cs_defs.h:528
Definition: cs_defs.h:332
cs_real_t cs_real_2_t[2]
Definition: cs_defs.h:346
Definition: cs_defs.h:529
Definition: cs_defs.h:325
void cs_wall_condensation_0d_thermal_create(cs_lnum_t nvolumes, cs_lnum_t ncmast)
Create the context for 0D wall condensation thermal models.
Definition: cs_wall_condensation_1d_thermal.c:331
void cs_wall_condensation_0d_thermal_free(void)
Free structures related to 0D wall condensation models.
Definition: cs_wall_condensation_1d_thermal.c:365
cs_wall_cond_0d_thermal_t * cs_get_glob_wall_cond_0d_thermal(void)
Provide writeable access to cs_wall_cond_0d_thermal_t structure.
Definition: cs_wall_condensation_1d_thermal.c:401
const cs_wall_cond_1d_thermal_t * cs_glob_wall_cond_1d_thermal
Definition: cs_wall_condensation_1d_thermal.c:129
cs_wall_cond_1d_thermal_t * cs_get_glob_wall_cond_1d_thermal(void)
Provide writeable access to _wall_cond structure.
Definition: cs_wall_condensation_1d_thermal.c:387
void cs_wall_condensation_0d_thermal_solve(void)
Use 0-D thermal model to solve the temperature and themal flux at the volume structure walls.
Definition: cs_wall_condensation_1d_thermal.c:414
const cs_wall_cond_0d_thermal_t * cs_glob_wall_cond_0d_thermal
Definition: cs_wall_condensation_1d_thermal.c:132
void cs_wall_condensation_1d_thermal_create(int nzones)
Create the context for wall condensation thermal models.
Definition: cs_wall_condensation_1d_thermal.c:246
void cs_wall_condensation_1d_thermal_free(void)
Free all structures related to wall condensation models.
Definition: cs_wall_condensation_1d_thermal.c:304
void cs_wall_condensation_1d_thermal_mesh_create(int znmurx, int nfbpcd, int nzones)
Definition: cs_wall_condensation_1d_thermal.c:278
integer(c_int), pointer, save nvolumes
number of the volume strutures with a specific condensation source terms depending on the wall temper...
Definition: cs_nz_condensation.f90:174
integer(c_int), pointer, save ncmast
number of the cells in which a condensation source terms is imposed. See lstmast list and the subrout...
Definition: cs_nz_condensation.f90:167
integer(c_int), pointer, save nzones
number of the zones with a specific condensation source terms depending on the wall temperature and m...
Definition: cs_nz_condensation.f90:103
integer(c_int), pointer, save nfbpcd
number of faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine c...
Definition: cs_nz_condensation.f90:55
integer(c_int), pointer, save znmurx
Maximal number of discretized points associated to the (ii)th face with the 1-D thermal model coupled...
Definition: cs_nz_tagmr.f90:55
Definition: cs_wall_condensation_1d_thermal.h:62
cs_real_t * volume_rho
Definition: cs_wall_condensation_1d_thermal.h:68
cs_real_t * volume_thickness
Definition: cs_wall_condensation_1d_thermal.h:65
cs_lnum_t nvolumes
Definition: cs_wall_condensation_1d_thermal.h:64
cs_real_t * volume_cp
Definition: cs_wall_condensation_1d_thermal.h:69
cs_real_t * volume_surf
Definition: cs_wall_condensation_1d_thermal.h:72
cs_real_t * volume_measure
Definition: cs_wall_condensation_1d_thermal.h:74
cs_real_t * volume_lambda
Definition: cs_wall_condensation_1d_thermal.h:70
cs_real_t * volume_t0
Definition: cs_wall_condensation_1d_thermal.h:73
cs_real_t * volume_mass
Definition: cs_wall_condensation_1d_thermal.h:71
cs_real_2_t * volume_t
Definition: cs_wall_condensation_1d_thermal.h:66
Definition: cs_wall_condensation_1d_thermal.h:40
cs_real_t * ztpar
Definition: cs_wall_condensation_1d_thermal.h:55
cs_lnum_t * znmur
Definition: cs_wall_condensation_1d_thermal.h:46
cs_real_t * ztmur
Definition: cs_wall_condensation_1d_thermal.h:58
int znmurx
Definition: cs_wall_condensation_1d_thermal.h:43
cs_real_t * zepais
Definition: cs_wall_condensation_1d_thermal.h:47
int nzones
Definition: cs_wall_condensation_1d_thermal.h:42
cs_real_t * ztheta
Definition: cs_wall_condensation_1d_thermal.h:44
cs_real_t * zrob
Definition: cs_wall_condensation_1d_thermal.h:52
cs_real_t * zcondb
Definition: cs_wall_condensation_1d_thermal.h:53
cs_real_t * zdxp
Definition: cs_wall_condensation_1d_thermal.h:57
cs_real_t * zdxmin
Definition: cs_wall_condensation_1d_thermal.h:45
cs_real_t * zhext
Definition: cs_wall_condensation_1d_thermal.h:50
cs_real_t * ztext
Definition: cs_wall_condensation_1d_thermal.h:51
cs_real_t * ztpar0
Definition: cs_wall_condensation_1d_thermal.h:48
cs_real_t * zcpb
Definition: cs_wall_condensation_1d_thermal.h:54
