1 #ifndef __CS_VOLUME_MASS_INJECTION_H__
2 #define __CS_VOLUME_MASS_INJECTION_H__
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
@ gamma
Definition: cs_field_pointer.h:222
void cs_volume_mass_injection_build_lists(cs_lnum_t n_cells, cs_lnum_t cell_num[])
Build the list and zone ids of cells with volume mass injection.
Definition: cs_volume_mass_injection.c:535
void cs_volume_mass_injection_eval(int nvar, cs_lnum_t ncesmp, int itypsm[], cs_real_t smacel[])
Evaluate contributions to volume mass injection.
Definition: cs_volume_mass_injection.c:577
void cs_volume_mass_injection_flag_zones(void)
Flag volume zones with the appropriate CS_VOLUME_ZONE_MASS_SOURCE_TERM flag when at least one volume ...
Definition: cs_volume_mass_injection.c:493
void cs_volume_mass_injection_get_arrays(const cs_field_t *f, cs_lnum_t *ncesmp, cs_lnum_t **icetsm, int **itpsmp, cs_real_t **smcelp, cs_real_t **gamma)
Return pointers to the mass source term arrays.
Definition: cs_volume_mass_injection.c:688
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:188
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:182
integer, save nvar
number of solved variables (must be lower than nvarmx)
Definition: dimens.f90:42
Definition: cs_field.h:131
