8.2
cs_turbulence_v2f.h
1 #ifndef __CS_TURBULENCE_V2F_H__
2 #define __CS_TURBULENCE_V2F_H__
5  * V2F turbulence model.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function prototypes
44 /*----------------------------------------------------------------------------*/
63
64 void
66  cs_lnum_t icetsm[],
67  int itypsm[],
68  const cs_real_t *dt,
69  cs_real_t smacel[],
70  const cs_real_t prdv2f[]);
71
76 /*----------------------------------------------------------------------------*/
77
78 void
80
81 /*----------------------------------------------------------------------------*/
86
87 void
89
91
93
94 #endif /* __CS_TURBULENCE_V2F_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
@ dt
void cs_turbulence_v2f_bl_v2k_mu_t(void)
Calculation of turbulent viscosity for the V2F-BL model.
Definition: cs_turbulence_v2f.cpp:1272
void cs_turbulence_v2f_phi_mu_t(void)
Calculation of turbulent viscosity for the V2F-phi model.
Definition: cs_turbulence_v2f.cpp:1227
void cs_turbulence_v2f(cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t *dt, cs_real_t smacel[], const cs_real_t prdv2f[])
Solve the V2F phi-model equations.
Definition: cs_turbulence_v2f.cpp:1094
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:188
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:182
