8.2
cs_saddle_solver.h
1 #ifndef __CS_SADDLE_SOLVER_H__
2 #define __CS_SADDLE_SOLVER_H__
5  * Solvers for saddle-point systems arising from CDO discretizations
30 #include "cs_defs.h"
37  * Local headers
40 #include "cs_cdo_blas.h"
41 #include "cs_cdo_system.h"
42 #include "cs_iter_algo.h"
43 #include "cs_param_saddle.h"
44 #include "cs_sles.h"
45
46 /*----------------------------------------------------------------------------*/
49
51  * Macro definitions
53
55  * Type definitions
57
58 /*----------------------------------------------------------------------------*/
69 /*----------------------------------------------------------------------------*/
70
71 typedef void
73  const cs_real_t *vec,
74  const cs_adjacency_t *mat_adj,
75  const cs_real_t *mat_op,
76  cs_real_t *matvec);
77
78 /*
79  * Main structure to solve a saddle-point problem described as follows
80  *
81  * | M11 | M12 | | x1 | |rhs1 |
82  * M = |-----------| |----| = |-----|
83  * | M21 | 0 | | x2 | |rhs2 |
84  *
85  * One assumes that M12 = M21^T
86  */
87
88 typedef struct {
89
90  /* Set of parameters to know how to solve the saddle-point system (shared) */
91
93
94  /* Structure to handle iterative algorithms */
95
97
98  /* Description of the saddle-point system to solve (shared) */
99
101
102  bool do_setup;
103
104  /* Main SLES structure associated to the saddle-point problem. According to
105  * the type of saddle-point solver, additional SLES can be allocated, for
106  * instance to compute an approximation of the Schur complement. */
107
109
110  /* Scatter viewpoint */
111
116
119
120  /* Additional members according to the type of saddle-point solver. This
121  * structure is cast on-the-fly */
122
123  void *context;
124
125  /* Monitoring */
126
127  unsigned n_calls;
128  unsigned n_iter_min;
129  unsigned n_iter_max;
130  unsigned n_iter_tot;
131
133
134
135 /* ==================================================== */
136 /* List of context structures dedicated to some solvers */
137 /* ==================================================== */
138
139 /* Context structure for the ALU algorithm */
140 /* --------------------------------------- */
141
142 typedef struct {
143
144  /* Auxiliary buffers */
145
146  cs_real_t *inv_m22; /* reciprocal of the mass matrix for the (2,2)
147  * block; buffer of size n2_dofs */
148  cs_real_t *res2; /* buffer of size n2_dofs */
149  cs_real_t *m21x1; /* buffer of size n2_dofs */
150
151  cs_real_t *b1_tilda; /* Modified RHS (size n1_dofs) */
152  cs_real_t *rhs; /* buffer of size n1_dofs */
153
154  /* SLES associated to the transformation of the right-hand side */
155
157
158  /* Function pointers for computing operations needed in the algorithm */
159  /* ------------------------------------------------------------------ */
160
164
165  /* Shared pointers */
166
168
169  /* Indexed list used to scan the unassembled m21 operator */
170
172
174
175
176 /* Context structure for block preconditioner used in combination with a Krylov
177  * solver such as MINRES or GCR.
178  * ----------------------------------------------------------------------------
179  *
180  * A hybrid storage is used to represent the system described below
181  *
182  * | M11 | M12 | | x1 | |rhs1 |
183  * M = |-----------| |----| = |-----|
184  * | M21 | 0 | | x2 | |rhs2 |
185  *
186  * One assumes that M12 = M21^T
187  */
188
189 typedef struct {
190
191  /* Shortcut on pointers available through the system helper */
192
195
196  /* Max. size of the blocks (scatter or gather view). This size takes into
197  account the size needed for synchronization. */
198
201
202  /* SLES structure associated to the Schur complement. It depends on the type
203  of Schur complement approximation used */
204
208
209  /* Native arrays for the Schur matrix (optional) */
210
213
214  /* Diagonal approximations of block matrices (optional) */
215
218
220
221  /* Function pointers */
222
225
226  /* Shared pointers */
227
228  const cs_property_t *pty_22; /* Property related to the (2,2) block */
230  const cs_adjacency_t *m21_adj; /* Indexed list used to scan the unassembled
231  m21 operator */
232
234
235
236 /* Context structure for the GKB algorithm */
237 /* --------------------------------------- */
238 /* This structure follows the algorithm given in the article entitled "An
239  * iterative generalized Golub-Kahan algorithm for problems in structural
240  * mechanics" by M. Arioli, C. Kruse, U. Ruede and N. Tardieu
241  */
242
243 typedef struct {
244
245  /* Orthogonalization coefficients */
246
250
251  /* Energy norm estimation */
252
256
257  /* Auxiliary buffers */
258
259  cs_real_t *q; /* buffer of size n2_dofs */
260  cs_real_t *d; /* buffer of size n2_dofs */
261  cs_real_t *m21v; /* buffer of size n2_dofs */
262  cs_real_t *inv_m22; /* reciprocal of the mass matrix for the (2,2)
263  * block; buffer of size n2_dofs */
264  const cs_real_t *m22; /* mass matrix for the (2,2) block (shared pointer) */
265
266  cs_real_t *w; /* buffer of size n1_dofs */
267  cs_real_t *m12q; /* buffer of size n1_dofs */
268  cs_real_t *v; /* buffer of size n1_dofs */
269  cs_real_t *x1_tilda; /* buffer of size n1_dofs */
270
271  cs_real_t *rhs_tilda; /* buffer of size MAX(n1_dofs, n2_dofs) */
272
273  /* Optional SLES to perform the transformation of the right hand-side */
274
276
277  /* Function pointers */
278
282
283  /* Shared pointers */
284
286
287  /* Indexed list used to scan the unassembled m21 operator */
288
290
292
293
294 /* Context structure for the Notay's algebraic transformation */
295 /* ---------------------------------------------------------- */
296
297 typedef struct {
298
299  /* Function pointer */
300
302
303  /* Shared pointers */
304
306
307  /* Indexed list used to scan the unassembled m21 operator */
308
310
312
313
314 /* Context structure for the Uzawa-CG algorithm */
315 /* -------------------------------------------- */
316
317 typedef struct {
318
319  /* Auxiliary scaling coefficient */
320
322
323  /* Auxiliary buffers */
324
325  cs_real_t *res2; /* buffer of size n2_dofs */
326  cs_real_t *m21x1; /* buffer of size n2_dofs */
327  cs_real_t *gk; /* buffer of size n2_dofs */
328
329  cs_real_t *b1_tilda; /* Modified RHS (size n1_dofs) */
330  cs_real_t *dzk; /* buffer of size n1_dofs */
331  cs_real_t *rhs; /* buffer of size n1_dofs */
332
333  /* Function pointers */
334
338
339  /* Shortcut on pointers available through the system helper */
340
343
344  /* Max. size of the blocks (scatter or gather view). This size takes into
345  account the size needed for synchronization. */
346
349
350  /* SLES structure associated to the Schur complement. It depends on the type
351  of Schur complement approximation used */
352
353  cs_real_t *inv_m22; /* reciprocal of the mass matrix for the
354  * (2,2) block; buffer of size n2_dofs */
357
358  /* Native arrays for the Schur matrix (optional) */
359
362
363  /* Diagonal approximations of block matrices (optional) */
364
366
369
370  /* Shared pointers */
371
372  const cs_property_t *pty_22; /* Property related to the (2,2) block */
374  const cs_adjacency_t *m21_adj; /* Indexed list used to scan the unassembled
375  m21 operator */
376
378
379
380 /*============================================================================
381  * Public function prototypes
382  *============================================================================*/
383
384 /*----------------------------------------------------------------------------*/
390 /*----------------------------------------------------------------------------*/
391
392 int
394
395 /*----------------------------------------------------------------------------*/
403 /*----------------------------------------------------------------------------*/
404
406 cs_saddle_solver_by_id(int id);
407
408 /*----------------------------------------------------------------------------*/
423 /*----------------------------------------------------------------------------*/
424
427  int n1_dofs_by_elt,
428  cs_lnum_t n2_elts,
429  int n2_dofs_by_elt,
430  const cs_param_saddle_t *saddlep,
432  cs_sles_t *main_sles);
433
434 /*----------------------------------------------------------------------------*/
438 /*----------------------------------------------------------------------------*/
439
440 void
442
443 /*----------------------------------------------------------------------------*/
449 /*----------------------------------------------------------------------------*/
450
451 void
453
454 /*----------------------------------------------------------------------------*/
460 /*----------------------------------------------------------------------------*/
461
462 void
464
465 /*----------------------------------------------------------------------------*/
472 /*----------------------------------------------------------------------------*/
473
474 void
476  unsigned n_iter);
477
478 /*----------------------------------------------------------------------------*/
482 /*----------------------------------------------------------------------------*/
483
484 void
486
487 /*----------------------------------------------------------------------------*/
501 /*----------------------------------------------------------------------------*/
502
503 cs_real_t *
505  const cs_matrix_t *m11,
506  const cs_range_set_t *b11_rset,
507  cs_sles_t *xtra_sles,
508  int *n_iter);
509
510 /*----------------------------------------------------------------------------*/
525 /*----------------------------------------------------------------------------*/
526
527 void
529  const cs_real_t *x2,
530  const cs_adjacency_t *m21_adj,
531  const cs_real_t *m21_val,
532  cs_real_t *m12x2);
533
534 /*----------------------------------------------------------------------------*/
549 /*----------------------------------------------------------------------------*/
550
551 void
553  const cs_real_t *x2,
554  const cs_adjacency_t *m21_adj,
555  const cs_real_t *m21_val,
556  cs_real_t *m12x2);
557
558 /*----------------------------------------------------------------------------*/
570 /*----------------------------------------------------------------------------*/
571
572 void
574  const cs_real_t *x1,
575  const cs_adjacency_t *m21_adj,
576  const cs_real_t *m21_val,
577  cs_real_t *m21x1);
578
579 /*----------------------------------------------------------------------------*/
591 /*----------------------------------------------------------------------------*/
592
593 void
595  const cs_real_t *x1,
596  const cs_adjacency_t *m21_adj,
597  const cs_real_t *m21_val,
598  cs_real_t *m21x1);
599
600 /*----------------------------------------------------------------------------*/
607 /*----------------------------------------------------------------------------*/
608
609 void
611
612 /*----------------------------------------------------------------------------*/
619 /*----------------------------------------------------------------------------*/
620
621 void
623 (
625 );
626
627 /*----------------------------------------------------------------------------*/
633 /*----------------------------------------------------------------------------*/
634
635 void
637 (
639 );
640
641 /*----------------------------------------------------------------------------*/
649 /*----------------------------------------------------------------------------*/
650
651 void
653  cs_saddle_solver_t *solver);
654
655 /*----------------------------------------------------------------------------*/
662 /*----------------------------------------------------------------------------*/
663
664 void
666 (
668 );
669
670 /*----------------------------------------------------------------------------*/
677 /*----------------------------------------------------------------------------*/
678
679 void
681 (
683 );
684
685 /*----------------------------------------------------------------------------*/
691 /*----------------------------------------------------------------------------*/
692
693 void
695
696 /*----------------------------------------------------------------------------*/
703 /*----------------------------------------------------------------------------*/
704
705 void
707
708 /*----------------------------------------------------------------------------*/
714 /*----------------------------------------------------------------------------*/
715
716 void
718 (
720 );
721
722 /*----------------------------------------------------------------------------*/
729 /*----------------------------------------------------------------------------*/
730
731 void
733
734 /*----------------------------------------------------------------------------*/
742 /*----------------------------------------------------------------------------*/
743
744 void
746  cs_saddle_solver_t *solver);
747
748 /*----------------------------------------------------------------------------*/
755 /*----------------------------------------------------------------------------*/
756
757 void
759 (
761 );
762
763 /*----------------------------------------------------------------------------*/
769 /*----------------------------------------------------------------------------*/
770
771 void
773 (
775 );
776
777 /*----------------------------------------------------------------------------*/
787 /*----------------------------------------------------------------------------*/
788
789 void
791  cs_real_t *x1,
792  cs_real_t *x2);
793
794 /*----------------------------------------------------------------------------*/
808 /*----------------------------------------------------------------------------*/
809
810 void
812  cs_real_t *x1,
813  cs_real_t *x2);
814
815 /*----------------------------------------------------------------------------*/
826 /*----------------------------------------------------------------------------*/
827
828 void
830  cs_real_t *x1,
831  cs_real_t *x2);
832
833 /*----------------------------------------------------------------------------*/
842 /*----------------------------------------------------------------------------*/
843
844 void
846  cs_real_t *x1,
847  cs_real_t *x2);
848
849 /*----------------------------------------------------------------------------*/
860 /*----------------------------------------------------------------------------*/
861
862 void
864  cs_real_t *x1,
865  cs_real_t *x2);
866
867 /*----------------------------------------------------------------------------*/
876 /*----------------------------------------------------------------------------*/
877
878 void
880  cs_real_t *x1,
881  cs_real_t *x2);
882
883 /*----------------------------------------------------------------------------*/
894 /*----------------------------------------------------------------------------*/
895
896 void
898  cs_real_t *x1,
899  cs_real_t *x2);
900
901 /*----------------------------------------------------------------------------*/
902
904
905 #endif /* __CS_SADDLE_SOLVER_H__ */
cs_real_t() cs_cdo_blas_square_norm_t(const cs_real_t *array)
Generic function pointer for computing a square norm. Parallel synchronization is performed.
Definition: cs_cdo_blas.h:79
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
@ x2
Definition: cs_field_pointer.h:224
Definition: cs_matrix.h:110
Handle the settings of saddle-point systems. These systems arise from the monolithic coupling of the ...
void cs_saddle_solver_gcr(cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
Apply the GCR algorithm to a saddle point problem (the system is stored in a hybrid way)....
Definition: cs_saddle_solver.c:3827
cs_saddle_solver_t * cs_saddle_solver_add(cs_lnum_t n1_elts, int n1_dofs_by_elt, cs_lnum_t n2_elts, int n2_dofs_by_elt, const cs_param_saddle_t *saddlep, cs_cdo_system_helper_t *sh, cs_sles_t *main_sles)
Add a new solver for solving a saddle-point problem.
Definition: cs_saddle_solver.c:2083
void cs_saddle_solver_m21_multiply_scalar(cs_lnum_t n2_dofs, const cs_real_t *x1, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m21x1)
Compute the resulting vector of the operation m21*x1 The stride is equal to 1 for the operator m21 op...
Definition: cs_saddle_solver.c:2512
void cs_saddle_solver_context_alu_clean(cs_saddle_solver_context_alu_t *ctx)
Free main memory consuming part of the context structure associated to an ALU algorithm.
Definition: cs_saddle_solver.c:2604
void cs_saddle_solver_context_uzawa_cg_create(cs_lnum_t b22_max_size, cs_saddle_solver_t *solver)
Create and initialize the context structure for an algorithm related to the Uzawa-CG algorithm.
Definition: cs_saddle_solver.c:2986
void cs_saddle_solver_uzawa_cg(cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
Apply the Uzawa-CG algorithm to solve a saddle point problem (the system is stored in a hybrid way)....
Definition: cs_saddle_solver.c:4359
void cs_saddle_solver_context_notay_create(cs_saddle_solver_t *solver)
Create and initialize the context structure for the algorithm relying on the Notay's algebraic transf...
Definition: cs_saddle_solver.c:2947
void cs_saddle_solver_free(cs_saddle_solver_t **p_solver)
Free a cs_saddle_solver_t structure.
Definition: cs_saddle_solver.c:2134
void cs_saddle_solver_context_block_pcd_create(cs_lnum_t b22_max_size, cs_saddle_solver_t *solver)
Create and initialize the context structure for a block preconditioner used in combination with a Kry...
Definition: cs_saddle_solver.c:2656
void cs_saddle_solver_minres(cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
Apply the MINRES algorithm to a saddle point problem (the system is stored in a hybrid way)....
Definition: cs_saddle_solver.c:3571
cs_real_t * cs_saddle_solver_m11_inv_lumped(cs_saddle_solver_t *solver, const cs_matrix_t *m11, const cs_range_set_t *b11_rset, cs_sles_t *xtra_sles, int *n_iter)
Retrieve the lumped matrix the inverse of the diagonal of the (1,1)-block matrix. The storage of a ma...
Definition: cs_saddle_solver.c:2340
void cs_saddle_solver_gkb_inhouse(cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
Apply the GKB algorithm to a saddle point problem (the system is stored in a hybrid way)....
Definition: cs_saddle_solver.c:4052
void cs_saddle_solver_update_monitoring(cs_saddle_solver_t *solver, unsigned n_iter)
Update the current monitoring state with n_iter.
Definition: cs_saddle_solver.c:2286
void cs_saddle_solver_alu_incr(cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
Apply the Augmented Lagrangian-Uzawa algorithm to a saddle point problem (the system is stored in a h...
Definition: cs_saddle_solver.c:3172
void cs_saddle_solver_context_gkb_free(cs_saddle_solver_context_gkb_t **p_ctx)
Free the context structure associated to the GKB algorithm.
Definition: cs_saddle_solver.c:2922
void cs_saddle_solver_finalize(void)
Free all remaining structures related to saddle-point solvers.
Definition: cs_saddle_solver.c:2119
void cs_saddle_solver_context_alu_free(cs_saddle_solver_context_alu_t **p_ctx)
Free the context structure associated to an ALU algorithm.
Definition: cs_saddle_solver.c:2630
void cs_saddle_solver_notay(cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
Apply the Notay's transformation algorithm to solve a saddle point problem (the system is stored in a...
Definition: cs_saddle_solver.c:3398
void cs_saddle_solver_log_monitoring(void)
Log the monitoring performance of all saddle-point systems.
Definition: cs_saddle_solver.c:2309
void cs_saddle_solver_context_gkb_create(cs_saddle_solver_t *solver)
Create and initialize the context structure for the GKB algorithm.
Definition: cs_saddle_solver.c:2811
void cs_saddle_solver_sles_full_system(cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2)
Apply an (external) solver to solve a saddle point problem (the system is stored in a monolithic way)...
Definition: cs_saddle_solver.c:4212
void cs_saddle_solver_context_alu_create(cs_saddle_solver_t *solver)
Create and initialize the context structure for an algorithm related to the ALU algorithm.
Definition: cs_saddle_solver.c:2542
void cs_saddle_solver_context_uzawa_cg_clean(cs_saddle_solver_context_uzawa_cg_t *ctx)
Free main memory consuming part of the context structure associated to a Uzawa-CG algorithm.
Definition: cs_saddle_solver.c:3107
void cs_saddle_solver_context_gkb_clean(cs_saddle_solver_context_gkb_t *ctx)
Free the main memory consuming part of the context structure associated to the GKB algorithm.
Definition: cs_saddle_solver.c:2884
cs_saddle_solver_t * cs_saddle_solver_by_id(int id)
Get a pointer to saddle-point solver from its id.
Definition: cs_saddle_solver.c:2056
int cs_saddle_solver_get_n_systems(void)
Retrieve the number of saddle-point systems which have been added.
Definition: cs_saddle_solver.c:2040
void cs_saddle_solver_context_block_pcd_clean(cs_saddle_solver_context_block_pcd_t *ctx)
Free the context structure for a block preconditioner used in combination with a Krylov solver such a...
Definition: cs_saddle_solver.c:2757
void cs_saddle_solver_m12_multiply_scalar(cs_lnum_t n2_elts, const cs_real_t *x2, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m12x2)
Compute the resulting vector of the operation m12*x2 The stride is equal to 1 for the operator m21 (u...
Definition: cs_saddle_solver.c:2443
void cs_saddle_solver_m12_multiply_vector(cs_lnum_t n2_dofs, const cs_real_t *x2, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m12x2)
Compute the resulting vector of the operation m12*x2 The stride is equal to 3 for the operator m21 (u...
Definition: cs_saddle_solver.c:2396
void cs_saddle_solver_m21_multiply_vector(cs_lnum_t n2_dofs, const cs_real_t *x1, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m21x1)
Compute the resulting vector of the operation m21*x1 The stride is equal to 3 for the operator m21 op...
Definition: cs_saddle_solver.c:2477
void cs_saddle_solver_clean(cs_saddle_solver_t *solver)
Free/reset only a part of a cs_saddle_solver_t structure.
Definition: cs_saddle_solver.c:2214
void cs_saddle_solver_context_uzawa_cg_free(cs_saddle_solver_context_uzawa_cg_t **p_ctx)
Free the context structure associated to a Uzawa-CG algorithm.
Definition: cs_saddle_solver.c:3144
void cs_saddle_solver_context_block_pcd_free(cs_saddle_solver_context_block_pcd_t **p_ctx)
Definition: cs_saddle_solver.c:2787
void() cs_saddle_solver_matvec_t(cs_lnum_t n2_dofs, const cs_real_t *vec, const cs_adjacency_t *mat_adj, const cs_real_t *mat_op, cs_real_t *matvec)
Generic function prototype to perform a matrix vector operation This operation takes place between an...
Definition: cs_saddle_solver.h:72
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
Definition: cs_cdo_system.h:377
Definition: cs_iter_algo.h:289
Structure storing all metadata related to the resolution of a saddle-point linear system....
Definition: cs_param_saddle.h:272
Definition: cs_range_set.h:57
Definition: cs_saddle_solver.h:142
cs_sles_t * init_sles
Definition: cs_saddle_solver.h:156
cs_saddle_solver_matvec_t * m12_vector_multiply
Definition: cs_saddle_solver.h:162
cs_real_t * rhs
Definition: cs_saddle_solver.h:152
cs_real_t * b1_tilda
Definition: cs_saddle_solver.h:151
cs_real_t * inv_m22
Definition: cs_saddle_solver.h:146
const cs_adjacency_t * m21_adj
Definition: cs_saddle_solver.h:171
const cs_real_t * m21_val
Definition: cs_saddle_solver.h:167
cs_saddle_solver_matvec_t * m21_vector_multiply
Definition: cs_saddle_solver.h:163
cs_real_t * m21x1
Definition: cs_saddle_solver.h:149
cs_real_t * res2
Definition: cs_saddle_solver.h:148
cs_cdo_blas_square_norm_t * square_norm_b11
Definition: cs_saddle_solver.h:161
Definition: cs_saddle_solver.h:189
cs_real_t * schur_diag
Definition: cs_saddle_solver.h:211
cs_range_set_t * b11_range_set
Definition: cs_saddle_solver.h:194
Definition: cs_saddle_solver.h:223
cs_real_t * m11_inv_diag
Definition: cs_saddle_solver.h:216
cs_matrix_t * m11
Definition: cs_saddle_solver.h:193
cs_sles_t * xtra_sles
Definition: cs_saddle_solver.h:219
const cs_property_t * pty_22
Definition: cs_saddle_solver.h:228
cs_matrix_t * schur_matrix
Definition: cs_saddle_solver.h:205
Definition: cs_saddle_solver.h:230
Definition: cs_saddle_solver.h:229
double schur_scaling
Definition: cs_saddle_solver.h:207
cs_sles_t * schur_sles
Definition: cs_saddle_solver.h:206
Definition: cs_saddle_solver.h:224
cs_lnum_t b11_max_size
Definition: cs_saddle_solver.h:199
cs_real_t * m22_mass_diag
Definition: cs_saddle_solver.h:217
cs_real_t * schur_xtra
Definition: cs_saddle_solver.h:212
Definition: cs_saddle_solver.h:200
Definition: cs_saddle_solver.h:243
cs_real_t zeta_square_sum
Definition: cs_saddle_solver.h:255
Definition: cs_saddle_solver.h:275
cs_real_t * rhs_tilda
Definition: cs_saddle_solver.h:271
Definition: cs_saddle_solver.h:280
cs_real_t alpha
Definition: cs_saddle_solver.h:247
cs_real_t * m21v
Definition: cs_saddle_solver.h:261
cs_real_t zeta
Definition: cs_saddle_solver.h:249
cs_real_t * m12q
Definition: cs_saddle_solver.h:267
cs_real_t * inv_m22
Definition: cs_saddle_solver.h:262
cs_real_t * zeta_array
Definition: cs_saddle_solver.h:254
Definition: cs_saddle_solver.h:289
const cs_real_t * m22
Definition: cs_saddle_solver.h:264
Definition: cs_saddle_solver.h:285
cs_real_t beta
Definition: cs_saddle_solver.h:248
Definition: cs_saddle_solver.h:281
cs_real_t * q
Definition: cs_saddle_solver.h:259
int zeta_size
Definition: cs_saddle_solver.h:253
cs_real_t * x1_tilda
Definition: cs_saddle_solver.h:269
cs_real_t * d
Definition: cs_saddle_solver.h:260
Definition: cs_saddle_solver.h:279
cs_real_t * w
Definition: cs_saddle_solver.h:266
cs_real_t * v
Definition: cs_saddle_solver.h:268
Definition: cs_saddle_solver.h:297
Definition: cs_saddle_solver.h:301
Definition: cs_saddle_solver.h:309
Definition: cs_saddle_solver.h:305
Definition: cs_saddle_solver.h:317
Definition: cs_saddle_solver.h:368
Definition: cs_saddle_solver.h:360
Definition: cs_saddle_solver.h:342
Definition: cs_saddle_solver.h:336
cs_real_t * gk
Definition: cs_saddle_solver.h:327
Definition: cs_saddle_solver.h:365
cs_real_t * rhs
Definition: cs_saddle_solver.h:331
cs_matrix_t * m11
Definition: cs_saddle_solver.h:341
Definition: cs_saddle_solver.h:329
Definition: cs_saddle_solver.h:367
cs_real_t alpha
Definition: cs_saddle_solver.h:321
Definition: cs_saddle_solver.h:372
Definition: cs_saddle_solver.h:355
cs_real_t * dzk
Definition: cs_saddle_solver.h:330
cs_real_t * inv_m22
Definition: cs_saddle_solver.h:353
Definition: cs_saddle_solver.h:374
Definition: cs_saddle_solver.h:373
Definition: cs_saddle_solver.h:356
Definition: cs_saddle_solver.h:337
cs_real_t * m21x1
Definition: cs_saddle_solver.h:326
cs_real_t * res2
Definition: cs_saddle_solver.h:325
Definition: cs_saddle_solver.h:347
Definition: cs_saddle_solver.h:335
Definition: cs_saddle_solver.h:361
Definition: cs_saddle_solver.h:348
Definition: cs_saddle_solver.h:88
cs_cdo_system_helper_t * system_helper
Definition: cs_saddle_solver.h:100
cs_sles_t * main_sles
Definition: cs_saddle_solver.h:108
cs_lnum_t n1_scatter_dofs
Definition: cs_saddle_solver.h:117
bool do_setup
Definition: cs_saddle_solver.h:102
cs_lnum_t n2_elts
Definition: cs_saddle_solver.h:114
unsigned n_calls
Definition: cs_saddle_solver.h:127
cs_lnum_t n1_elts
Definition: cs_saddle_solver.h:112
cs_iter_algo_t * algo
Definition: cs_saddle_solver.h:96
cs_lnum_t n2_scatter_dofs
Definition: cs_saddle_solver.h:118
unsigned n_iter_max
Definition: cs_saddle_solver.h:129
int n2_dofs_by_elt
Definition: cs_saddle_solver.h:115
unsigned n_iter_tot
Definition: cs_saddle_solver.h:130
unsigned n_iter_min
Definition: cs_saddle_solver.h:128
const cs_param_saddle_t * param
Definition: cs_saddle_solver.h:92
int n1_dofs_by_elt
Definition: cs_saddle_solver.h:113
void * context
Definition: cs_saddle_solver.h:123
