8.2
cs_notebook.h
1 #ifndef __CS_NOTEBOOK_H__
2 #define __CS_NOTEBOOK_H__
5  * Notebook management.
29  * Local headers
32 #include "cs_defs.h"
34 /*----------------------------------------------------------------------------*/
39 /*
40  * \brief Initialize the notebook object (based on cs_tree_node_t).
41  */
44 void
46
47 /*----------------------------------------------------------------------------*/
48 /*
49  * \brief Check if a parameter value is present.
50  *
51  * \param[in] name name of the parameter
52  * \param[out] editable 1 if the value is editable, 0 otherwise (optional)
53  *
54  * \return 0 if not present, 1 if present
55  */
56 /*----------------------------------------------------------------------------*/
57
58 int
59 cs_notebook_parameter_is_present(const char *name,
60  int *editable);
61
63 /*
64  * \brief Return a parameter value (real).
65  *
66  * The name used is the same as the one in the GUI.
67  *
68  * \param[in] name name of the parameter
69  *
70  * \return value of the given parameter
71  */
73
75 cs_notebook_parameter_value_by_name(const char *name);
76
77 /*----------------------------------------------------------------------------*/
78 /*
79  * \brief Set a parameter value (real) for an editable parameter.
80  *
81  * The name used is the same as the one in the GUI.
82  *
83  * \param[in] name name of the parameter
84  * \param[in] val value of the parameter
85  */
86 /*----------------------------------------------------------------------------*/
87
88 void
89 cs_notebook_parameter_set_value(const char *name,
90  cs_real_t val);
91
92 /*----------------------------------------------------------------------------*/
93 /*
94  * \brief Indicate whether the parameter is used for a study with openturns.
95  *
96  * Returns an int flag to indicate whether this paramter is used for an
97  * OpenTurns study.
98  * -1 : The parameter is not used with OpenTurns
99  * 0 : The parameter is used as an input from OpenTurns
100  * 1 : The parameter is used as an output to OpenTurns
101  *
102  * \param[in] name name of the parameter
103  *
104  * \return an int flag value
105  */
106 /*----------------------------------------------------------------------------*/
107
108 int
110
111 /*----------------------------------------------------------------------------*/
112 /*
113  * \brief Returns the description of the parameter (GUI defined).
114  *
115  * \param[in] name name of the parameter
116  *
117  * \return a const char pointer containing the description.
118  */
119 /*----------------------------------------------------------------------------*/
120
121 const char *
123
124 /*----------------------------------------------------------------------------*/
125 /*
126  * \brief Get id associated with a notebook parameter.
127  *
128  * \param[in] name name of the parameter
129  *
130  * \return -1 if not present, id if present
131  */
132 /*----------------------------------------------------------------------------*/
133
134 int
135 cs_notebook_parameter_get_id(const char *name);
136
137 /*----------------------------------------------------------------------------*/
138 /*
139  * \brief Get a group of notebook variable values
140  *
141  * \param[in] n number of notebook variables to query
142  * \param[in] ids ids of notebook variables to query
143  * (value set to 0 where id < 0)
144  * \param[out] values values of notebook variables to query
145  */
147
148 void
150  const int ids[],
151  double values[]);
152
153 /*----------------------------------------------------------------------------*/
154 /*
155  * \brief Set a group of notebook variable values
156  *
157  * \param[in] n number of notebook variables to set
158  * \param[in] ids ids of notebook variables to set
159  * (ignored where id < 0)
160  * \param[in] values values of notebook variables to set
161  */
162 /*----------------------------------------------------------------------------*/
163
164 void
166  const int ids[],
167  const double values[]);
168
169 /*----------------------------------------------------------------------------*/
170 /*
171  * \brief Destroy the notebook structure.
172  *
173  * Destroys the structures related to the notebook.
174  */
175 /*----------------------------------------------------------------------------*/
176
177 void
179
180 /*----------------------------------------------------------------------------*/
181 /*
182  * \brief Output the notebook info to the setup log.
183  */
184 /*----------------------------------------------------------------------------*/
185
186 void
188
189 /*----------------------------------------------------------------------------*/
193 /*----------------------------------------------------------------------------*/
194
195 void
196 cs_notebook_log(void);
197
198 /*----------------------------------------------------------------------------*/
199 /*
200  * \brief Number of notebook variables
201  *
202  * \returns number of notebook variables (int)
203  */
204 /*----------------------------------------------------------------------------*/
205
206 int
207 cs_notebook_nb_var(void);
208
209 /*----------------------------------------------------------------------------*/
210 /*
211  * \brief Indicate if the notebook parameter is editable
212  *
213  * Returns a boolean to indicate wheter this parameter is editable
214  *
215  * \param[in] id Id of the notebook parameter
216  *
217  * \returns true is variable can be edited, false otherwise
218  */
219 /*----------------------------------------------------------------------------*/
220
221 bool
223
224 /*----------------------------------------------------------------------------*/
225 /*
226  * \brief Indicate if the notebook parameter is read at restart
227  *
228  * Returns a boolean to indicate wheter this parameter is read at restart
229  *
230  * \param[in] id Id of the notebook parameter
231  *
232  * \returns true if variable should be read from checkpoint file, false otherwise
233  */
234 /*----------------------------------------------------------------------------*/
235
236 bool
238
239 /*----------------------------------------------------------------------------*/
240 /*
241  * \brief Change the editable property of the notebook parameter
242  *
243  * \param[in] id Id of the notebook parameter
244  * \param[in] val flag (bool) indicating if the value is set to editable
245  */
246 /*----------------------------------------------------------------------------*/
247
248 void
250  bool val);
251
253 /*
254  * \brief Get name of a notebook parameter based on its id
255  *
256  * \param[in] id Id of the notebook parameter
257  * \param[out] name Name of the notebook parameter
258  *
259  * \returns name of variable (char *)
260  */
261 /*----------------------------------------------------------------------------*/
262
263 const char *
264 cs_notebook_name_by_id(int id);
265
266 /*----------------------------------------------------------------------------*/
267 /*
268  * \brief Write uncertain values to output file.
269  *
270  * If input and output uncertain variables are provided, output values
271  * are written to an output file: cs_uncertain_output.dat
272  * Results are ordered in the definition order in the notebook.
273  */
274 /*----------------------------------------------------------------------------*/
275
276 void
278
279 /*----------------------------------------------------------------------------*/
280
282
283 #endif /* __CS_NOTEBOOK_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
int cs_notebook_parameter_is_present(const char *name, int *editable)
Definition: cs_notebook.c:378
void cs_notebook_uncertain_output(void)
Definition: cs_notebook.c:797
cs_real_t cs_notebook_parameter_value_by_name(const char *name)
Definition: cs_notebook.c:410
void cs_notebook_get_values(int n, const int ids[], double values[])
Get a group of notebook variable values.
Definition: cs_notebook.c:511
void cs_notebook_log_setup(void)
Definition: cs_notebook.c:593
void cs_notebook_log(void)
Print values of editable notebook variables to default log file.
Definition: cs_notebook.c:632
int cs_notebook_parameter_get_id(const char *name)
Definition: cs_notebook.c:492
int cs_notebook_nb_var(void)
Number of notebook variables.
Definition: cs_notebook.c:700
void cs_notebook_parameter_set_value(const char *name, cs_real_t val)
Definition: cs_notebook.c:428
void cs_notebook_var_change_editable(int id, bool val)
Change the editable property of the notebook parameter.
Definition: cs_notebook.c:757
void cs_notebook_load_from_file(void)
Definition: cs_notebook.c:288
int cs_notebook_parameter_get_openturns_status(char *name)
Definition: cs_notebook.c:458
void cs_notebook_set_values(int n, const int ids[], const double values[])
Set a group of notebook variable values.
Definition: cs_notebook.c:536
bool cs_notebook_var_is_editable(int id)
Indicate if the notebook parameter is editable.
Definition: cs_notebook.c:718
void cs_notebook_destroy_all(void)
Definition: cs_notebook.c:563
bool cs_notebook_var_is_read_from_checkpoint(int id)
Indicate if the notebook parameter is read at restart.
Definition: cs_notebook.c:739
const char * cs_notebook_name_by_id(int id)
Get name of a notebook parameter based on its id.
Definition: cs_notebook.c:778
const char * cs_notebook_parameter_get_description(char *name)
Definition: cs_notebook.c:475
