8.2
cs_medcoupling_postprocess.h
1 #ifndef __CS_MEDCOUPLING_POSTPROCESS_HXX__
2 #define __CS_MEDCOUPLING_POSTPROCESS_HXX__
5  * Postprocessing utilities based on MEDCoupling functions
31  * Local headers
34 #include "cs_defs.h"
41  * Type definitions
45  * Structure definitions
48 typedef struct _medcoupling_slice_t cs_medcoupling_slice_t;
49
51  * Public function prototypes
53
54 /*----------------------------------------------------------------------------*/
55 /*
56  * Get pointer to a slice based on id
57  *
58  * return pointer to slice. Raises an error if index is out of
59  * bounds.
60  */
61 /*----------------------------------------------------------------------------*/
62
63 cs_medcoupling_slice_t *
65
67 /*
68  * Get pointer to slice based on name, raises an error
69  * if not found.
70  *
71  * return pointer to slice, raises error if not found.
72  */
73 /*----------------------------------------------------------------------------*/
74
75 cs_medcoupling_slice_t *
76 cs_medcoupling_slice_by_name(const char *name);
77
78 /*----------------------------------------------------------------------------*/
79 /*
80  * Get pointer to slice based on name. Returns NULL if
81  * not found.
82  *
83  * return pointer to slice, NULL if not found.
84  */
86
87 cs_medcoupling_slice_t *
88 cs_medcoupling_slice_by_name_try(const char *name);
89
91 /*
92  * Add a slice based on a plane.
93  */
94 /*----------------------------------------------------------------------------*/
95
96 void
98  const char *selection_criteria,
99  const cs_real_t origin[],
100  const cs_real_t normal[],
101  const cs_real_t length1,
102  const cs_real_t length2);
103
104 /*----------------------------------------------------------------------------*/
105 /*
106  * Add a slice based on a disc
107  */
108 /*----------------------------------------------------------------------------*/
109
110 void
112  const char *selection_criteria,
113  const cs_real_t origin[],
114  const cs_real_t normal[],
115  const cs_real_t radius,
116  const int n_sectors);
117
118 /*----------------------------------------------------------------------------*/
119 /*
120  * Add a slice based on an annulus
121  */
123
124 void
126  const char *selection_criteria,
127  const cs_real_t origin[],
128  const cs_real_t normal[],
129  const cs_real_t radius1,
130  const cs_real_t radius2,
131  const int n_sectors);
132
133 /*----------------------------------------------------------------------------*/
134 /*
135  * Get number cells that may be intersected by the slice.
136  *
137  * return Number of elements
138  */
139 /*----------------------------------------------------------------------------*/
140
141 cs_lnum_t
142 cs_medcoupling_slice_get_n_elts(const char *name);
143
144 /*----------------------------------------------------------------------------*/
145 /*
146  * Get list of ids of the elements which may be intersected.
147  *
148  * return Pointer to list of ids (cs_lnum_t *). Do not deallocate!
149  */
150 /*----------------------------------------------------------------------------*/
151
152 cs_lnum_t *
153 cs_medcoupling_slice_get_elt_ids(const char *name);
154
155 /*----------------------------------------------------------------------------*/
156 /*
157  * Get list of intersection surfaces for each cell intersected.
158  *
159  * return Pointer to list of intersection surfaces (cs_real_t *)
160  */
161 /*----------------------------------------------------------------------------*/
162
163 cs_real_t *
164 cs_medcoupling_slice_get_surfaces(const char *name);
165
166 /*----------------------------------------------------------------------------*/
167 /*
168  * Get total intersection surface between a slice and volume mesh
169  *
170  * return Value of total intersection surface
171  */
172 /*----------------------------------------------------------------------------*/
173
174 cs_real_t
176
177 /*----------------------------------------------------------------------------*/
178 /*
179  * Activate postprocessing of intersected cells
180  */
181 /*----------------------------------------------------------------------------*/
182
183 void
185 (
186  const char *name
187 );
188
189 /*----------------------------------------------------------------------------*/
190 /*
191  * Compute integral of a scalar over a slice.
192  *
193  * return Global integrated value. A cs_parall_sum is used.
194  */
195 /*----------------------------------------------------------------------------*/
196
197 cs_real_t
198 cs_medcoupling_slice_scalar_integral(const char *name,
199  const cs_real_t *scalar);
200
201 /*----------------------------------------------------------------------------*/
202 /*
203  * Compute mean value of a scalar over a slice.
204  *
205  * return Global integrated value. A cs_parall_sum is used.
206  */
207 /*----------------------------------------------------------------------------*/
208
209 cs_real_t
210 cs_medcoupling_slice_scalar_mean(const char *name,
211  const cs_real_t *scalar);
212
213 /*----------------------------------------------------------------------------*/
214 /*
215  * Compute integral of a scalar over a slice using a scalar and/or
216  * vectorial weights. If NULL is provided for both weights,
217  * the non-weighted function is called.
218  *
219  * return Computed integral value over entire slice (parallel)
220  */
221 /*----------------------------------------------------------------------------*/
222
223 cs_real_t
225  const cs_real_t *scalar,
226  const cs_real_t *weight_s,
227  const cs_real_3_t *weight_v);
228
229 /*----------------------------------------------------------------------------*/
230 /*
231  * Compute mean of a scalar over a slice using a scalar and/or vectorial
232  * weights. If NULL is provided for both weights, the non-weighted
233  * function is called.
234  *
235  * return Computed mean value over entire slice (parallel)
236  */
237 /*----------------------------------------------------------------------------*/
238
239 cs_real_t
241  const cs_real_t *scalar,
242  const cs_real_t *weight_s,
243  const cs_real_3_t *weight_v);
244
245 /*----------------------------------------------------------------------------*/
246 /*
247  * Destroy all slices
248  */
249 /*----------------------------------------------------------------------------*/
250
251 void
253
254 /*----------------------------------------------------------------------------*/
255
257
258 #endif /* __CS_MEDCOUPLING_POSTPROCESS_HXX__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
Definition: cs_defs.h:529
Definition: cs_defs.h:325
cs_real_t cs_medcoupling_slice_scalar_integral(const char *name, const cs_real_t *scalar)
Definition: cs_medcoupling_postprocess.cxx:875
void cs_medcoupling_slice_destroy_all(void)
Destroy all slices.
Definition: cs_medcoupling_postprocess.cxx:1058
void cs_medcoupling_postprocess_add_annulus_slice(const char *name, const char *selection_criteria, const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius1, const cs_real_t radius2, const int n_sectors)
Add a slice based on an annulus.
Definition: cs_medcoupling_postprocess.cxx:734
cs_real_t cs_medcoupling_slice_scalar_integral_weighted(const char *name, const cs_real_t *scalar, const cs_real_t *weight_s, const cs_real_3_t *weight_v)
Compute integral of a scalar over a slice using a scalar and/or vectorial weights....
Definition: cs_medcoupling_postprocess.cxx:932
cs_medcoupling_slice_t * cs_medcoupling_slice_by_name_try(const char *name)
Get pointer to slice based on name. Returns NULL if not found.
Definition: cs_medcoupling_postprocess.cxx:615
void cs_medcoupling_postprocess_add_plane_slice(const char *name, const char *selection_criteria, const cs_real_t origin[], const cs_real_t normal[], const cs_real_t length1, const cs_real_t length2)
Definition: cs_medcoupling_postprocess.cxx:642
cs_real_t * cs_medcoupling_slice_get_surfaces(const char *name)
Definition: cs_medcoupling_postprocess.cxx:820
void cs_medcoupling_slice_activate_postprocess(const char *name)
Activate postprocessing of intersected cells.
Definition: cs_medcoupling_postprocess.cxx:856
cs_medcoupling_slice_t * cs_medcoupling_slice_by_id(int id)
Get pointer to a slice based on id.
Definition: cs_medcoupling_postprocess.cxx:570
cs_real_t cs_medcoupling_slice_scalar_mean_weighted(const char *name, const cs_real_t *scalar, const cs_real_t *weight_s, const cs_real_3_t *weight_v)
Compute mean of a scalar over a slice using a scalar and/or vectorial weights. If NULL is provided fo...
Definition: cs_medcoupling_postprocess.cxx:995
cs_lnum_t * cs_medcoupling_slice_get_elt_ids(const char *name)
Definition: cs_medcoupling_postprocess.cxx:801
cs_real_t cs_medcoupling_slice_scalar_mean(const char *name, const cs_real_t *scalar)
Definition: cs_medcoupling_postprocess.cxx:908
cs_real_t cs_medcoupling_slice_get_total_surface(const char *name)
Get total intersection surface between a slice and volume mesh.
Definition: cs_medcoupling_postprocess.cxx:839
cs_lnum_t cs_medcoupling_slice_get_n_elts(const char *name)
Definition: cs_medcoupling_postprocess.cxx:782
cs_medcoupling_slice_t * cs_medcoupling_slice_by_name(const char *name)
Get pointer to slice based on name, raises an error if not found.
Definition: cs_medcoupling_postprocess.cxx:591
void cs_medcoupling_postprocess_add_disc_slice(const char *name, const char *selection_criteria, const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius, const int n_sectors)
Add a slice based on a disc.
Definition: cs_medcoupling_postprocess.cxx:691
