1 #ifndef __CS_MEDCOUPLING_MESH_HXX__
2 #define __CS_MEDCOUPLING_MESH_HXX__
47 #if defined(HAVE_MEDCOUPLING)
49 #include "MEDCouplingUMesh.hxx"
51 using namespace MEDCoupling;
81 #if defined(HAVE_MEDCOUPLING)
110 const char *selection_criteria,
249 #if defined(HAVE_MEDCOUPLING)
273 #if defined(HAVE_MEDCOUPLING)
281 const int n_sectors);
298 #if defined(HAVE_MEDCOUPLING)
307 const int n_sectors);
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
const cs_lnum_t * cs_medcoupling_mesh_get_vertex_list(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's (parent) vertices list.
Definition: cs_medcoupling_mesh.cxx:1124
const cs_lnum_t * cs_medcoupling_mesh_get_connectivity(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's (parent) elements list.
Definition: cs_medcoupling_mesh.cxx:1145
cs_lnum_t cs_medcoupling_mesh_get_n_elts(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's number of elements.
Definition: cs_medcoupling_mesh.cxx:1062
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_ids(cs_mesh_t *csmesh, const char *name, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int elt_dim, int use_bbox)
create a new cs_medcoupling_mesh_t instance based on cs_mesh_t
Definition: cs_medcoupling_mesh.cxx:948
cs_lnum_t cs_medcoupling_mesh_get_n_vertices(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's number of vertices.
Definition: cs_medcoupling_mesh.cxx:1103
void cs_medcoupling_mesh_destroy(cs_medcoupling_mesh_t *mesh)
Destroy a cs_medcoupling_mesh_t.
Definition: cs_medcoupling_mesh.cxx:995
MEDCouplingUMesh * cs_medcoupling_create_disc_mesh(const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius, const int n_sectors)
Returns a pointer to a MEDCouplingUMesh of a disc.
Definition: cs_medcoupling_mesh.cxx:1246
MEDCouplingUMesh * cs_medcoupling_create_annulus_mesh(const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius1, const cs_real_t radius2, const int n_sectors)
Returns a pointer to a MEDCouplingUMesh of an annulus.
Definition: cs_medcoupling_mesh.cxx:1343
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_base(cs_mesh_t *csmesh, const char *name, const char *selection_criteria, int elt_dim, int use_bbox)
Definition: cs_medcoupling_mesh.cxx:889
void cs_medcoupling_mesh_destroy_all(void)
Destroy all cs_medcoupling_mesh_t instances.
Definition: cs_medcoupling_mesh.cxx:1017
int cs_medcoupling_mesh_get_dim(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's spatial dimension.
Definition: cs_medcoupling_mesh.cxx:1042
MEDCouplingUMesh * cs_medcoupling_create_plane_mesh(const cs_real_t origin[], const cs_real_t normal[], const cs_real_t length1, const cs_real_t length2)
Returns a pointer to a MEDCouplingUMesh of a plane.
Definition: cs_medcoupling_mesh.cxx:1173
const cs_lnum_t * cs_medcoupling_mesh_get_elt_list(cs_medcoupling_mesh_t *m)
Definition: cs_medcoupling_mesh.cxx:1082
Definition: cs_medcoupling_mesh.hxx:61
char * sel_criteria
Definition: cs_medcoupling_mesh.hxx:63
cs_lnum_t n_vtx
Definition: cs_medcoupling_mesh.hxx:72
cs_lnum_t n_elts
Definition: cs_medcoupling_mesh.hxx:68
cs_lnum_t * vtx_list
Definition: cs_medcoupling_mesh.hxx:73
cs_lnum_t * new_to_old
Definition: cs_medcoupling_mesh.hxx:76
MEDCouplingUMesh * med_mesh
Definition: cs_medcoupling_mesh.hxx:82
int elt_dim
Definition: cs_medcoupling_mesh.hxx:66
cs_lnum_t * elt_list
Definition: cs_medcoupling_mesh.hxx:69
cs_real_t * bbox
Definition: cs_medcoupling_mesh.hxx:79
